Beam Design - CL A _1.6-2.5
Design Span (L): 14.50 ft.
Clear Span: 14.25 ft.
Total Span: 14.75 ft.
Live Load: 20 plf
Dead Load: 20 plf
Selfweight: 126.9 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 129.1 lbs
Notes: NAUMAN
Beam Design CHRISTIAN GUNN PO BOX 76006, TAMPA, FLORIDA 201690
6/3/2022 1
6/3/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (174.00 + 3)] x (12 in./ft.)3 = 3.46 ft3
Volumespan = N[A x L] = 2 x [16.88 x 174.00] x (12 in./ft.)3 = 3.40 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.46 = 129.1 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.40 = 126.9 lbs
20 plf
20 plf
ws = 8.75 plf
14.50 ft.
14.25 ft.
14.75 ft.
359.53 lbs
359.53 lbs
6/3/2022 3
Fbx' = (750)(1.15)(1)(0.8)(1)(1)(1)(1) = 690.0 psi
fb = = 243.0 psi
 fb = 243.0 psi < Fbx' = 690.0 psi  (CSI = 0.35)   ➜  OK
6/3/2022 4
Fvx' = (175)(1.15)(1)(0.8)(1) = 161.00 psi
fv* = = 13.68 psi
 fv* = 13.68 psi < Fvx' = 161.00 psi  (CSI = 0.08)   ➜  OK
fv = = 15.71 psi
 fv = 15.71 psi < Fvx' = 161.00 psi  (CSI = 0.10)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1400000(1)(0.9)(1) = 1260000 psi
6/3/2022 5
ΔLL = = 0.04 in.
(L/d)LL = 174.00 / 0.04 = 3923
 ΔLL = 0.04 in = L/3923 < L/180   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 174.00 / 0.11 = 1610
 ΔTL = 0.11 in = L/1610 < L/120   ➜  OK
Fc⊥x' = (565)(1)(0.8)(1) = 452.00 psi
fc⊥ = = 39.9 psi
 fc⊥ = 39.9 psi < Fc⊥x' = 452.00 psi  (CSI = 0.09)   ➜  OK
6/3/2022 6
