Size: 3.5 x 13.5
Design Span (L): 19.50 ft.
Clear Span: 19.00 ft.
Total Span: 20.00 ft.
Dead Load: 250 plf
Selfweight: 216.0 lbs
Dist. Selfweight: 11.08 plf
Total Weight: 221.6 lbs
Beam Design 2022A37
1/18/2022 1
d = 13.500 in.
A = 3.500 x 13.500 = 47.25 in.2
Sx = (3.500)(13.500)2/6 = 106.31 in.3
Sy = (3.500)2(13.500)/6 = 27.56 in.3
Ix = (3.500)(13.500)3/12 = 717.61 in.4
Iy = (3.500)3(13.500)/12 = 48.23 in.4
Beam Design 2022A37
1/18/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [47.25 x (234.00 + 6)] x (12 in./ft.)3 = 6.56 ft3
Volumespan = N[A x L] = 1 x [47.25 x 234.00] x (12 in./ft.)3 = 6.40 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.56 = 221.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.40 = 216.0 lbs
Distributed Self Weight (ws) = = 11.08 plf
250 plf
  ws = 11.08 plf
19.50 ft.
19.00 ft.
3610.78 lbs
3610.78 lbs
Beam Design 2022A37
1/18/2022 3
fb = = 1937.2 psi
 fb = 1937.2 psi < Fbx' = 2400.0 psi  (CSI = 0.81)   ➜  OK
Beam Design 2022A37
1/18/2022 4
fv* = = 98.87 psi
 fv* = 98.87 psi < Fvx' = 265.00 psi  (CSI = 0.37)   ➜  OK
fv = = 111.76 psi
 fv = 111.76 psi < Fvx' = 265.00 psi  (CSI = 0.42)   ➜  OK
Beam Design 2022A37
1/18/2022 5
ΔLL = = 0.25 in.
(L/d)LL = 234.00 / 0.25 = 929
 ΔLL = 0.25 in = L/929 < L/360   ➜  OK
ΔTL = = 0.91 in.
(L/d)TL = 234.00 / 0.91 = 257
 ΔTL = 0.91 in = L/257 < L/240   ➜  OK
fc⊥ = = 171.9 psi
 fc⊥ = 171.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.26)   ➜  OK
Beam Design 2022A37
1/18/2022 6
