Beam Design - bill
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Live Load: 905 lbs
Dead Load: 6.8 lbs
Selfweight: 177.4 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 180.4 lbs
Beam Design bill toey 18069 Stanaford Road, Danese, WV, 25831 1
6/3/2022 1
6/3/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (177.00 + 3)] x (12 in./ft.)3 = 5.27 ft3
Volumespan = N[A x L] = 3 x [16.88 x 177.00] x (12 in./ft.)3 = 5.19 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 5.27 = 180.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.19 = 177.4 lbs
905 lbs
6.8 lbs
ws = 12.02 plf
14.75 ft.
14.50 ft.
15.00 ft.
546.09 lbs
546.09 lbs
6/3/2022 3
fb = = 466.4 psi
 fb = 466.4 psi < Fbx' = 1035.0 psi  (CSI = 0.45)   ➜  OK
6/3/2022 4
fv* = = 15.80 psi
 fv* = 15.80 psi < Fvx' = 207.00 psi  (CSI = 0.08)   ➜  OK
fv = = 16.14 psi
 fv = 16.14 psi < Fvx' = 207.00 psi  (CSI = 0.08)   ➜  OK
6/3/2022 5
ΔLL =   =   = 0.12 in.
(L/d)LL = 177.00 / 0.12 = 1446
 ΔLL = 0.12 in = L/1446 < L/180   ➜  OK
ΔTL =   =   = 0.14 in.
(L/d)TL = 177.00 / 0.14 = 1280
 ΔTL = 0.14 in = L/1280 < L/120   ➜  OK
fc⊥ = = 40.5 psi
 fc⊥ = 40.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.06)   ➜  OK
6/3/2022 6
