Species: Hem-Fir
Grade: HF No.2
Size: 4 x 8
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 120 plf
Dead Load: 360 plf
Selfweight: 94.2 lbs
Dist. Selfweight: 16.38 plf
Total Weight: 98.3 lbs
Beam Design 2022A365
6/3/2022 1
G = 0.43
6/3/2022 2
= 30.99 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [25.38 x (69.00 + 3)] x (12 in./ft.)3 = 3.17 ft3
Volumespan = N[A x L] = 3 x [25.38 x 69.00] x (12 in./ft.)3 = 3.04 ft3
Total Weight (WT) = ρw x Volumetotal = 30.99 x 3.17 = 98.3 lbs
Self Weight (WS) = ρw x Volumespan = 30.99 x 3.04 = 94.2 lbs
Distributed Self Weight (ws) = = 16.38 plf
120 plf
360 plf
ws = 16.38 plf
5.75 ft.
5.50 ft.
1489.14 lbs
1489.14 lbs
6/3/2022 3
Fbx' = (850)(1.15)(1)(1)(1)(1.3)(1)(1) = 1270.8 psi
fb = = 267.6 psi
 fb = 267.6 psi < Fbx' = 1270.8 psi  (CSI = 0.21)   ➜  OK
6/3/2022 4
fv* = = 22.21 psi
 fv* = 22.21 psi < Fvx' = 167.32 psi  (CSI = 0.13)   ➜  OK
fv = = 28.12 psi
 fv = 28.12 psi < Fvx' = 167.32 psi  (CSI = 0.17)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(0.9)(1)(1) = 1170000 psi
6/3/2022 5
ΔLL = = 0.01 in.
(L/d)LL = 69.00 / 0.01 = 9121
 ΔLL = 0.01 in = L/9121 < L/180   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 69.00 / 0.03 = 2205
 ΔTL = 0.03 in = L/2205 < L/120   ➜  OK
fc⊥ = = 47.3 psi
 fc⊥ = 47.3 psi < Fc⊥x' = 271.35 psi  (CSI = 0.17)   ➜  OK
6/3/2022 6
