Species: Hem-Fir
Grade: HF No.2
Size: 4 x 8
Live Load: 120 plf
Dead Load: 360 plf
Selfweight: 192.5 lbs
Dist. Selfweight: 16.38 plf
Total Weight: 196.6 lbs
Beam Design 2022A364
6/3/2022 1
G = 0.43
6/3/2022 2
= 30.99 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [25.38 x (141.00 + 3)] x (12 in./ft.)3 = 6.34 ft3
Volumespan = N[A x L] = 3 x [25.38 x 141.00] x (12 in./ft.)3 = 6.21 ft3
Total Weight (WT) = ρw x Volumetotal = 30.99 x 6.34 = 196.6 lbs
Self Weight (WS) = ρw x Volumespan = 30.99 x 6.21 = 192.5 lbs
Distributed Self Weight (ws) = = 16.38 plf
120 plf
360 plf
ws = 16.38 plf
2978.29 lbs
2978.29 lbs
6/3/2022 3
Fbx' = (850)(1.15)(1)(1)(1)(1.3)(1)(1) = 1270.8 psi
fb = = 1117.6 psi
 fb = 1117.6 psi < Fbx' = 1270.8 psi  (CSI = 0.88)   ➜  OK
6/3/2022 4
fv* = = 51.55 psi
 fv* = 51.55 psi < Fvx' = 167.32 psi  (CSI = 0.31)   ➜  OK
fv = = 57.46 psi
 fv = 57.46 psi < Fvx' = 167.32 psi  (CSI = 0.34)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(0.9)(1)(1) = 1170000 psi
6/3/2022 5
ΔLL = = 0.13 in.
(L/d)LL = 141.00 / 0.13 = 1069
 ΔLL = 0.13 in = L/1069 < L/180   ➜  OK
ΔTL = = 0.55 in.
(L/d)TL = 141.00 / 0.55 = 258
 ΔTL = 0.55 in = L/258 < L/120   ➜  OK
fc⊥ = = 94.5 psi
 fc⊥ = 94.5 psi < Fc⊥x' = 271.35 psi  (CSI = 0.35)   ➜  OK
6/3/2022 6
