Grade: SP DSS
Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Selfweight: 79.1 lbs
Dist. Selfweight: 9.04 plf
Total Weight: 81.4 lbs
Load Duration: 1.33
Beam Design 2022A359
6/2/2022 1
6/2/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (105.00 + 3)] x (12 in./ft.)3 = 2.11 ft3
Volumespan = N[A x L] = 2 x [16.88 x 105.00] x (12 in./ft.)3 = 2.05 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 2.11 = 81.4 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 2.05 = 79.1 lbs
Distributed Self Weight (ws) = = 9.04 plf
ws = 9.04 plf
8.75 ft.
8.50 ft.
9.00 ft.
828.19 lbs
828.19 lbs
6/2/2022 3
Fbx' = (1800)(1.33)(0.85)(1)(1)(1)(1)(1) = 2034.9 psi
fb = = 334.0 psi
 fb = 334.0 psi < Fbx' = 2034.9 psi  (CSI = 0.16)   ➜  OK
6/2/2022 4
Fvx' = (175)(1.33)(0.97)(1)(1) = 225.77 psi
fv* = = 28.12 psi
 fv* = 28.12 psi < Fvx' = 225.77 psi  (CSI = 0.12)   ➜  OK
fv = = 35.79 psi
 fv = 35.79 psi < Fvx' = 225.77 psi  (CSI = 0.16)   ➜  OK
6/2/2022 5
ΔLL = = 0.02 in.
(L/d)LL = 105.00 / 0.02 = 4846
 ΔLL = 0.02 in = L/4846 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 105.00 / 0.04 = 2633
 ΔTL = 0.04 in = L/2633 < L/240   ➜  OK
Fc⊥x' = (660)(0.67)(1)(1) = 442.20 psi
fc⊥ = = 92.0 psi
 fc⊥ = 92.0 psi < Fc⊥x' = 442.20 psi  (CSI = 0.21)   ➜  OK
6/2/2022 6
