Beam Design - Glulam Capacity Evaluation
Size: 5.125 x 27
Design Span (L): 49.58 ft.
Clear Span: 49.17 ft.
Total Span: 50.00 ft.
Bearing (lb): 5 in.
Live Load: 240 plf
Dead Load: 200 plf
Selfweight: 1608.6 lbs
Dist. Selfweight: 32.44 plf
Total Weight: 1622.1 lbs
Load Duration: 1.25
Notes: Glulam 5x27
Live Load: 12 psf
Dead Load: 10 psf
CV Volume Factor 0.846b - - - - -
Beam Design Amir Zamani 21R-140
6/1/2022 1
b = 5.125 in.
d = 27.000 in.
A = 5.125 x 27.000 = 138.38 in.2
Sx = (5.125)(27.000)2/6 = 622.69 in.3
Sy = (5.125)2(27.000)/6 = 118.20 in.3
Ix = (5.125)(27.000)3/12 = 8406.28 in.4
Iy = (5.125)3(27.000)/12 = 302.88 in.4
6/1/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [138.38 x (595.00 + 5)] x (12 in./ft.)3 = 48.05 ft3
Volumespan = N[A x L] = 1 x [138.38 x 595.00] x (12 in./ft.)3 = 47.65 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 48.05 = 1622.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 47.65 = 1608.6 lbs
Distributed Self Weight (ws) = = 32.44 plf
240 plf
200 plf
  ws = 32.44 plf
49.58 ft.
49.17 ft.
50.00 ft.
11810.98 lbs
11810.98 lbs
6/1/2022 3
CV = = 0.846
CV = 0.846 < CL = 1
Fbx' = (2400)(1.25)(1)(1)(0.846) = 2538.6 psi
fb = = 2797.9 psi
 fb = 2797.9 psi > Fbx' = 2538.6 psi  (CSI = 1.10)   ➜  NG
6/1/2022 4
fv* = = 115.44 psi
 fv* = 115.44 psi < Fvx' = 331.25 psi  (CSI = 0.35)   ➜  OK
fv = = 126.97 psi
 fv = 126.97 psi < Fvx' = 331.25 psi  (CSI = 0.38)   ➜  OK
6/1/2022 5
ΔLL = = 2.16 in.
(L/d)LL = 595.00 / 2.16 = 276
 ΔLL = 2.16 in = L/276 > L/360   ➜  NG
ΔTL = = 4.25 in.
(L/d)TL = 595.00 / 4.25 = 140
 ΔTL = 4.25 in = L/140 > L/240   ➜  NG
Ab = b x lb = 5.125 x 5 = 25.63 in2
fc⊥ = = 460.9 psi
 fc⊥ = 460.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.71)   ➜  OK
6/1/2022 6
