Species: Western Cedars
Grade: WC No.2
Size: 4 x 16
Design Span (L): 13.00 ft.
Clear Span: 12.67 ft.
Total Span: 13.33 ft.
Bearing (lb): 4 in.
Live Load: 154 plf
Dead Load: 110 plf
Selfweight: 119.4 lbs
Dist. Selfweight: 9.18 plf
Total Weight: 122.4 lbs
Incised Lumber: Yes
CL Beam Stability Factor 0.947 - - - - -
Beam Design 2022A354
5/31/2022 1
d = 15.000 in.
WC No.2 700 425 155 425 650 1000000 370000 0.36
G = 0.36
5/31/2022 2
= 25.18 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (156.00 + 4)] x (12 in./ft.)3 = 4.86 ft3
Volumespan = N[A x L] = 1 x [52.50 x 156.00] x (12 in./ft.)3 = 4.74 ft3
Total Weight (WT) = ρw x Volumetotal = 25.18 x 4.86 = 122.4 lbs
Self Weight (WS) = ρw x Volumespan = 25.18 x 4.74 = 119.4 lbs
Distributed Self Weight (ws) = = 9.18 plf
154 plf
110 plf
ws = 9.18 plf
13.00 ft.
12.67 ft.
13.33 ft.
1821.21 lbs
1821.21 lbs
5/31/2022 3
lu = Unbraced Length = 13.000 ft.
lu/d = = 10.40
le = 1.63lu + 3d = 1.63(156.0) + 3(15) = 299.28 in. = 24.94 ft.  (NDS Table 3.3.3)
Rb = = 19.14
 Rb = 19.14 < 50   ➜  OK
5/31/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 370000(1)(1)(0.95) = 351500 psi
FbE = = 1151.00 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (700)(1.15)(1)(1)(1)(0.8)(1) = 644.00 psi
CL =   = 0.947
Fbx' = (700)(1.15)(1)(1)(0.947)(1)(0.8)(1) = 609.7 psi
fb = = 527.6 psi
 fb = 527.6 psi < Fbx' = 609.7 psi  (CSI = 0.87)   ➜  OK
Fvx' = (155)(1.15)(1)(1)(0.8) = 142.60 psi
fv* = = 40.98 psi
 fv* = 40.98 psi < Fvx' = 142.60 psi  (CSI = 0.29)   ➜  OK
fv = = 50.73 psi
 fv = 50.73 psi < Fvx' = 142.60 psi  (CSI = 0.36)   ➜  OK
5/31/2022 5
Ex' = Ex(CM)(Ct)(Ci) = 1000000(1)(1)(0.95) = 950000 psi
ΔLL = = 0.11 in.
(L/d)LL = 156.00 / 0.11 = 1474
 ΔLL = 0.11 in = L/1474 < L/180   ➜  OK
ΔTL = = 0.19 in.
(L/d)TL = 156.00 / 0.19 = 831
 ΔTL = 0.19 in = L/831 < L/120   ➜  OK
Ab = b x lb = 3.5 x 4 = 14.00 in2
fc⊥ = = 130.1 psi
 fc⊥ = 130.1 psi < Fc⊥x' = 425.00 psi  (CSI = 0.31)   ➜  OK
5/31/2022 6
