Design Span (L): 19.29 ft.
Clear Span: 19.00 ft.
Total Span: 19.58 ft.
Bearing (lb): 3.5 in.
Selfweight: 168.8 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 171.3 lbs
Defl. Limits: 600|400
Beam Design 2022A351
5/30/2022 1
5/30/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (231.46 + 3.5)] x (12 in./ft.)3 = 4.59 ft3
Volumespan = N[A x L] = 2 x [16.88 x 231.46] x (12 in./ft.)3 = 4.52 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 4.59 = 171.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 4.52 = 168.8 lbs
ws = 8.75 plf
19.29 ft.
19.00 ft.
19.58 ft.
1798.87 lbs
1798.87 lbs
5/30/2022 3
Fbx' = (750)(1.00)(1)(1)(1)(1)(1)(1) = 750.0 psi
fb = = 1620.4 psi
 fb = 1620.4 psi > Fbx' = 750.0 psi  (CSI = 2.16)   ➜  NG
5/30/2022 4
fv* = = 71.10 psi
 fv* = 71.10 psi < Fvx' = 175.00 psi  (CSI = 0.41)   ➜  OK
fv = = 78.76 psi
 fv = 78.76 psi < Fvx' = 175.00 psi  (CSI = 0.45)   ➜  OK
LL Allowable: L/600
TL Allowable: L/400
5/30/2022 5
ΔLL = = 0.62 in.
(L/d)LL = 231.46 / 0.62 = 370
 ΔLL = 0.62 in = L/370 > L/600   ➜  NG
ΔTL = = 1.15 in.
(L/d)TL = 231.46 / 1.15 = 202
 ΔTL = 1.15 in = L/202 > L/400   ➜  NG
fc⊥ = = 171.3 psi
 fc⊥ = 171.3 psi < Fc⊥x' = 565.00 psi  (CSI = 0.30)   ➜  OK
5/30/2022 6
