Size: 3.5 x 6
Design Span (L): 12.25 ft.
Clear Span: 12.00 ft.
Total Span: 12.50 ft.
Live Load: 63 plf
Dead Load: 60 plf
Selfweight: 60.3 lbs
Dist. Selfweight: 4.92 plf
Total Weight: 61.5 lbs
Beam Design 2254
1/17/2022 1
d = 6.000 in.
A = 3.500 x 6.000 = 21.00 in.2
Sx = (3.500)(6.000)2/6 = 21.00 in.3
Sy = (3.500)2(6.000)/6 = 12.25 in.3
Ix = (3.500)(6.000)3/12 = 63.00 in.4
Iy = (3.500)3(6.000)/12 = 21.44 in.4
Beam Design 2254
1/17/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [21.00 x (147.00 + 3)] x (12 in./ft.)3 = 1.82 ft3
Volumespan = N[A x L] = 1 x [21.00 x 147.00] x (12 in./ft.)3 = 1.79 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1.82 = 61.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.79 = 60.3 lbs
Distributed Self Weight (ws) = = 4.92 plf
63 plf
60 plf
  ws = 4.92 plf
12.25 ft.
12.50 ft.
799.52 lbs
799.52 lbs
Beam Design 2254
1/17/2022 3
fb = = 1371.2 psi
 fb = 1371.2 psi < Fbx' = 2400.0 psi  (CSI = 0.57)   ➜  OK
Beam Design 2254
1/17/2022 4
fv* = = 51.40 psi
 fv* = 51.40 psi < Fvx' = 265.00 psi  (CSI = 0.19)   ➜  OK
fv = = 55.97 psi
 fv = 55.97 psi < Fvx' = 265.00 psi  (CSI = 0.21)   ➜  OK
Beam Design 2254
1/17/2022 5
ΔLL = = 0.28 in.
(L/d)LL = 147.00 / 0.28 = 522
 ΔLL = 0.28 in = L/522 < L/240   ➜  OK
ΔTL = = 0.57 in.
(L/d)TL = 147.00 / 0.57 = 257
 ΔTL = 0.57 in = L/257 < L/180   ➜  OK
fc⊥ = = 76.1 psi
 fc⊥ = 76.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.12)   ➜  OK
Beam Design 2254
1/17/2022 6
