Design Span (L): 19.29 ft.
Clear Span: 19.00 ft.
Total Span: 19.58 ft.
Bearing (lb): 3.5 in.
Selfweight: 84.4 lbs
Dist. Selfweight: 4.37 plf
Total Weight: 85.7 lbs
Beam Design 2022A349
5/30/2022 1
5/30/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (231.46 + 3.5)] x (12 in./ft.)3 = 2.29 ft3
Volumespan = N[A x L] = 1 x [16.88 x 231.46] x (12 in./ft.)3 = 2.26 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.29 = 85.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.26 = 84.4 lbs
ws = 4.37 plf
19.29 ft.
19.00 ft.
19.58 ft.
1756.05 lbs
1756.05 lbs
5/30/2022 3
Fbx' = (750)(1.00)(1)(1)(1)(1)(1)(1) = 750.0 psi
fb = = 3163.6 psi
 fb = 3163.6 psi > Fbx' = 750.0 psi  (CSI = 4.22)   ➜  NG
5/30/2022 4
fv* = = 138.82 psi
 fv* = 138.82 psi < Fvx' = 175.00 psi  (CSI = 0.79)   ➜  OK
fv = = 153.77 psi
 fv = 153.77 psi < Fvx' = 175.00 psi  (CSI = 0.88)   ➜  OK
5/30/2022 5
ΔLL = = 1.25 in.
(L/d)LL = 231.46 / 1.25 = 185
 ΔLL = 1.25 in = L/185 > L/360   ➜  NG
ΔTL = = 2.24 in.
(L/d)TL = 231.46 / 2.24 = 103
 ΔTL = 2.24 in = L/103 > L/240   ➜  NG
fc⊥ = = 334.5 psi
 fc⊥ = 334.5 psi < Fc⊥x' = 565.00 psi  (CSI = 0.59)   ➜  OK
5/30/2022 6
