Design Span (L): 10.75 ft.
Clear Span: 10.50 ft.
Total Span: 11.00 ft.
Live Load: 30 plf
Dead Load: 15 plf
Selfweight: 21.1 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 21.6 lbs
Beam Design 2022A346
5/28/2022 1
5/28/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (129.00 + 3)] x (12 in./ft.)3 = 0.63 ft3
Volumespan = N[A x L] = 1 x [8.25 x 129.00] x (12 in./ft.)3 = 0.62 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.63 = 21.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.62 = 21.1 lbs
30 plf
15 plf
ws = 1.96 plf
10.75 ft.
10.50 ft.
11.00 ft.
258.28 lbs
258.28 lbs
5/28/2022 3
fb = = 1076.4 psi
 fb = 1076.4 psi < Fbx' = 1345.5 psi  (CSI = 0.80)   ➜  OK
5/28/2022 4
fv* = = 41.98 psi
 fv* = 41.98 psi < Fvx' = 207.00 psi  (CSI = 0.20)   ➜  OK
fv = = 45.89 psi
 fv = 45.89 psi < Fvx' = 207.00 psi  (CSI = 0.22)   ➜  OK
5/28/2022 5
ΔLL = = 0.27 in.
(L/d)LL = 129.00 / 0.27 = 476
 ΔLL = 0.27 in = L/476 < L/360   ➜  OK
ΔTL = = 0.42 in.
(L/d)TL = 129.00 / 0.42 = 304
 ΔTL = 0.42 in = L/304 < L/240   ➜  OK
fc⊥ = = 57.4 psi
 fc⊥ = 57.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.09)   ➜  OK
5/28/2022 6
