Design Span (L): 10.25 ft.
Clear Span: 10.00 ft.
Total Span: 10.50 ft.
Selfweight: 41.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 42.1 lbs
CL Beam Stability Factor 0.973 - - - - -
Beam Design 2022A341
5/26/2022 1
5/26/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (123.00 + 3)] x (12 in./ft.)3 = 1.23 ft3
Volumespan = N[A x L] = 1 x [16.88 x 123.00] x (12 in./ft.)3 = 1.20 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.23 = 42.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.20 = 41.1 lbs
ws = 4.01 plf
10.25 ft.
10.00 ft.
10.50 ft.
939.79 lbs
939.79 lbs
5/26/2022 3
lu/d = = 2.13
Rb = = 15.72
 Rb = 15.72 < 50   ➜  OK
5/26/2022 4
FbE = = 2815.53 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1)(1)(1) = 1035.00 psi
CL =   = 0.973
Fbx' = (900)(1.15)(1)(1)(0.973)(1)(1)(1) = 1007.0 psi
fb = = 891.6 psi
 fb = 891.6 psi < Fbx' = 1007.0 psi  (CSI = 0.89)   ➜  OK
fv* = = 66.63 psi
 fv* = 66.63 psi < Fvx' = 207.00 psi  (CSI = 0.32)   ➜  OK
fv = = 81.55 psi
 fv = 81.55 psi < Fvx' = 207.00 psi  (CSI = 0.39)   ➜  OK
5/26/2022 5
ΔLL = = 0.09 in.
(L/d)LL = 123.00 / 0.09 = 1410
 ΔLL = 0.09 in = L/1410 < L/360   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 123.00 / 0.16 = 788
 ΔTL = 0.16 in = L/788 < L/240   ➜  OK
fc⊥ = = 208.8 psi
 fc⊥ = 208.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.33)   ➜  OK
5/26/2022 6
