Size: 5.125 x 21
Design Span (L): 28.08 ft.
Clear Span: 27.67 ft.
Total Span: 28.50 ft.
Bearing (lb): 5 in.
Live Load: 310 plf
Dead Load: 310 plf
Selfweight: 708.6 lbs
Dist. Selfweight: 25.23 plf
Total Weight: 719.1 lbs
CV Volume Factor 0.918b - - - - -
Beam Design 2022A338
5/24/2022 1
b = 5.125 in.
d = 21.000 in.
A = 5.125 x 21.000 = 107.63 in.2
Sx = (5.125)(21.000)2/6 = 376.69 in.3
Sy = (5.125)2(21.000)/6 = 91.93 in.3
Ix = (5.125)(21.000)3/12 = 3955.22 in.4
Iy = (5.125)3(21.000)/12 = 235.57 in.4
5/24/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [107.63 x (337.00 + 5)] x (12 in./ft.)3 = 21.30 ft3
Volumespan = N[A x L] = 1 x [107.63 x 337.00] x (12 in./ft.)3 = 20.99 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 21.30 = 719.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 20.99 = 708.6 lbs
Distributed Self Weight (ws) = = 25.23 plf
310 plf
310 plf
  ws = 25.23 plf
28.08 ft.
27.67 ft.
28.50 ft.
9194.46 lbs
9194.46 lbs
5/24/2022 3
CV = = 0.918
CV = 0.918 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.918) = 2204.4 psi
fb = = 2026.3 psi
 fb = 2026.3 psi < Fbx' = 2204.4 psi  (CSI = 0.92)   ➜  OK
5/24/2022 4
fv* = = 110.53 psi
 fv* = 110.53 psi < Fvx' = 265.00 psi  (CSI = 0.42)   ➜  OK
fv = = 126.27 psi
 fv = 126.27 psi < Fvx' = 265.00 psi  (CSI = 0.48)   ➜  OK
5/24/2022 5
ΔLL = = 0.61 in.
(L/d)LL = 337.00 / 0.61 = 553
 ΔLL = 0.61 in = L/553 < L/360   ➜  OK
ΔTL = = 1.27 in.
(L/d)TL = 337.00 / 1.27 = 266
 ΔTL = 1.27 in = L/266 < L/240   ➜  OK
Ab = b x lb = 5.125 x 5 = 25.63 in2
fc⊥ = = 358.8 psi
 fc⊥ = 358.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.55)   ➜  OK
5/24/2022 6
