Grade: SP SS
Size: 2 x 4
Design Span (L): 12.33 ft.
Clear Span: 12.17 ft.
Total Span: 12.50 ft.
Bearing (lb): 2 in.
Live Load: 20 plf
Dead Load: 1.5 plf
Selfweight: 17.3 lbs
Dist. Selfweight: 1.41 plf
Total Weight: 17.6 lbs
Load Duration: 1.33
Ct Temperature Factor 0.7 0.9 0.7 0.7 0.7 0.9
CL Beam Stability Factor 0.760 - - - - -
Beam Design 2022A331
5/24/2022 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
SP SS 2350 1650 175 565 1900 1800000 660000 0.55
5/24/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (148.00 + 2)] x (12 in./ft.)3 = 0.46 ft3
Volumespan = N[A x L] = 1 x [5.25 x 148.00] x (12 in./ft.)3 = 0.45 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.46 = 17.6 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.45 = 17.3 lbs
Distributed Self Weight (ws) = = 1.41 plf
20 plf
1.5 plf
ws = 1.41 plf
12.33 ft.
12.17 ft.
12.50 ft.
143.16 lbs
143.16 lbs
5/24/2022 3
lu = Unbraced Length = 12.333 ft.
lu/d = = 42.28
le = 1.63lu + 3d = 1.63(148.0) + 3(3.5) = 251.73 in. = 20.98 ft.  (NDS Table 3.3.3)
Rb = = 19.79
 Rb = 19.79 < 50   ➜  OK
5/24/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 660000(0.9)(0.9)(1) = 534600 psi
FbE = = 1638.26 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (2350)(1.33)(0.85)(0.7)(1)(1)(1) = 1859.67 psi
CL =   = 0.760
Fbx' = (2350)(1.33)(0.85)(0.7)(0.760)(1)(1)(1) = 1414.0 psi
fb = = 1706.5 psi
 fb = 1706.5 psi > Fbx' = 1414.0 psi  (CSI = 1.21)   ➜  NG
Fvx' = (175)(1.33)(0.97)(0.7)(1) = 158.04 psi
fv* = = 38.45 psi
 fv* = 38.45 psi < Fvx' = 158.04 psi  (CSI = 0.24)   ➜  OK
fv = = 40.36 psi
 fv = 40.36 psi < Fvx' = 158.04 psi  (CSI = 0.26)   ➜  OK
5/24/2022 5
Ex' = Ex(CM)(Ct)(Ci) = 1800000(0.9)(0.9)(1) = 1458000 psi
ΔLL = = 1.33 in.
(L/d)LL = 148.00 / 1.33 = 111
 ΔLL = 1.33 in = L/111 > L/360   ➜  NG
ΔTL = = 1.53 in.
(L/d)TL = 148.00 / 1.53 = 97
 ΔTL = 1.53 in = L/97 > L/240   ➜  NG
Fc⊥x' = (565)(0.67)(0.7)(1) = 264.99 psi
fc⊥ = = 47.7 psi
 fc⊥ = 47.7 psi < Fc⊥x' = 264.99 psi  (CSI = 0.18)   ➜  OK
5/24/2022 6
