Grade: SPF No.2
Design Span (L): 7.88 ft.
Clear Span: 7.75 ft.
Total Span: 8.00 ft.
Bearing (lb): 1.5 in.
Live Load: 0 lbs
Dead Load: 1000 lbs
Selfweight: 66.2 lbs
Dist. Selfweight: 8.41 plf
Total Weight: 67.3 lbs
Beam Design 2022A33
1/17/2022 1
Beam Design 2022A33
1/17/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (94.50 + 1.5)] x (12 in./ft.)3 = 2.31 ft3
Volumespan = N[A x L] = 3 x [13.88 x 94.50] x (12 in./ft.)3 = 2.28 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.31 = 67.3 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.28 = 66.2 lbs
Distributed Self Weight (ws) = = 8.41 plf
0 lbs
1000 lbs
ws = 8.41 plf
7.88 ft.
7.75 ft.
533.64 lbs
533.64 lbs
Beam Design 2022A33
1/17/2022 3
lu = Unbraced Length = 7.875 ft.
lu/d = = 10.22
le = 1.37lu + 3d = 1.37(94.5) + 3(9.25) = 157.22 in. = 13.10 ft.  (NDS Table 3.3.3)
Rb = = 8.47
 Rb = 8.47 < 50   ➜  OK
Beam Design 2022A33
1/17/2022 4
FbE = = 8521.98 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (875)(0.9)(1)(1)(1.1)(1)(1) = 866.25 psi
CL =   = 0.994
Fbx' = (875)(0.9)(1)(1)(0.994)(1.1)(1)(1) = 861.4 psi
fb = = 380.3 psi
 fb = 380.3 psi < Fbx' = 861.4 psi  (CSI = 0.44)   ➜  OK
Fvx' = (135)(0.9)(1)(1)(1) = 121.50 psi
fv* = = 18.98 psi
 fv* = 18.98 psi < Fvx' = 121.50 psi  (CSI = 0.16)   ➜  OK
fv = = 19.21 psi
 fv = 19.21 psi < Fvx' = 121.50 psi  (CSI = 0.16)   ➜  OK
Beam Design 2022A33
1/17/2022 5
ΔLL =   =   = 0.00 in.
(L/d)LL = 94.50 / 0.00 = ∞
ΔTL =   =   = 0.04 in.
(L/d)TL = 94.50 / 0.04 = 2145
 ΔTL = 0.04 in = L/2145 < L/240   ➜  OK
fc⊥ = = 79.1 psi
 fc⊥ = 79.1 psi < Fc⊥x' = 425.00 psi  (CSI = 0.19)   ➜  OK
Beam Design 2022A33
1/17/2022 6
