Size: 4 x 12
Design Span (L): 4.00 ft.
Clear Span: 3.75 ft.
Total Span: 4.25 ft.
Live Load: 800 plf
Dead Load: 96 plf
Selfweight: 38.8 lbs
Dist. Selfweight: 9.70 plf
Total Weight: 41.2 lbs
CF Size Factor 1.1 1 - 1 - -
Beam Design 2022A328
5/23/2022 1
5/23/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (48.00 + 3)] x (12 in./ft.)3 = 1.16 ft3
Volumespan = N[A x L] = 1 x [39.38 x 48.00] x (12 in./ft.)3 = 1.09 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 1.16 = 41.2 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 1.09 = 38.8 lbs
Distributed Self Weight (ws) = = 9.70 plf
800 plf
96 plf
ws = 9.70 plf
4.00 ft.
3.75 ft.
4.25 ft.
1924.61 lbs
1924.61 lbs
5/23/2022 3
fb = = 294.4 psi
 fb = 294.4 psi < Fbx' = 990.0 psi  (CSI = 0.30)   ➜  OK
5/23/2022 4
Fvx' = (180)(1.00)(0.97)(1)(1) = 174.60 psi
fv* = = 36.66 psi
 fv* = 36.66 psi < Fvx' = 174.60 psi  (CSI = 0.21)   ➜  OK
fv = = 69.01 psi
 fv = 69.01 psi < Fvx' = 174.60 psi  (CSI = 0.40)   ➜  OK
5/23/2022 5
ΔLL = = 0.01 in.
(L/d)LL = 48.00 / 0.01 = 6229
 ΔLL = 0.01 in = L/6229 < L/360   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 48.00 / 0.01 = 5502
 ΔTL = 0.01 in = L/5502 < L/240   ➜  OK
fc⊥ = = 183.3 psi
 fc⊥ = 183.3 psi < Fc⊥x' = 418.75 psi  (CSI = 0.44)   ➜  OK
5/23/2022 6
