Grade: DF SS
Size: 4 x 12
Design Span (L): 19.29 ft.
Clear Span: 19.04 ft.
Total Span: 19.54 ft.
Live Load: 133 plf
Dead Load: 16 plf
Selfweight: 187.1 lbs
Dist. Selfweight: 9.70 plf
Total Weight: 189.5 lbs
CF Size Factor 1.1 1 - 1 - -
Beam Design 2022A327
5/23/2022 1
5/23/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (231.48 + 3)] x (12 in./ft.)3 = 5.34 ft3
Volumespan = N[A x L] = 1 x [39.38 x 231.48] x (12 in./ft.)3 = 5.27 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 5.34 = 189.5 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 5.27 = 187.1 lbs
Distributed Self Weight (ws) = = 9.70 plf
133 plf
16 plf
ws = 9.70 plf
19.29 ft.
19.04 ft.
19.54 ft.
1550.48 lbs
1550.48 lbs
5/23/2022 3
Fbx' = (1500)(1.00)(0.85)(1)(1)(1.1)(1)(1) = 1402.5 psi
fb = = 1199.8 psi
 fb = 1199.8 psi < Fbx' = 1402.5 psi  (CSI = 0.86)   ➜  OK
5/23/2022 4
Fvx' = (180)(1.00)(0.97)(1)(1) = 174.60 psi
fv* = = 52.64 psi
 fv* = 52.64 psi < Fvx' = 174.60 psi  (CSI = 0.30)   ➜  OK
fv = = 58.31 psi
 fv = 58.31 psi < Fvx' = 174.60 psi  (CSI = 0.33)   ➜  OK
5/23/2022 5
ΔLL = = 0.58 in.
(L/d)LL = 231.48 / 0.58 = 397
 ΔLL = 0.58 in = L/397 < L/360   ➜  OK
ΔTL = = 0.70 in.
(L/d)TL = 231.48 / 0.70 = 332
 ΔTL = 0.70 in = L/332 < L/240   ➜  OK
fc⊥ = = 147.7 psi
 fc⊥ = 147.7 psi < Fc⊥x' = 418.75 psi  (CSI = 0.35)   ➜  OK
5/23/2022 6
