Design Span (L): 9.50 ft.
Clear Span: 9.25 ft.
Total Span: 9.75 ft.
Live Load: 80 plf
Dead Load: 20 plf
Selfweight: 31.3 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 32.1 lbs
Lateral Support: 8' o/c
CL Beam Stability Factor 0.785 - - - - -
Beam Design 2022A325
5/23/2022 1
5/23/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (114.00 + 3)] x (12 in./ft.)3 = 0.94 ft3
Volumespan = N[A x L] = 1 x [13.88 x 114.00] x (12 in./ft.)3 = 0.92 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.94 = 32.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.92 = 31.3 lbs
80 plf
20 plf
ws = 3.30 plf
9.50 ft.
9.25 ft.
9.75 ft.
503.57 lbs
503.57 lbs
5/23/2022 3
lu = Unbraced Length = 8 ft.
lu/d = = 10.38
le = 1.63lu + 3d = 1.63(96.0) + 3(9.25) = 184.23 in. = 15.35 ft.  (NDS Table 3.3.3)
Rb = = 27.52
 Rb = 27.52 < 50   ➜  OK
5/23/2022 4
FbE = = 918.95 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.00)(1)(1)(1.1)(1)(1) = 990.00 psi
CL =   = 0.785
Fbx' = (900)(1.00)(1)(1)(0.785)(1.1)(1)(1) = 777.1 psi
fb = = 653.7 psi
 fb = 653.7 psi < Fbx' = 777.1 psi  (CSI = 0.84)   ➜  OK
fv* = = 44.44 psi
 fv* = 44.44 psi < Fvx' = 180.00 psi  (CSI = 0.25)   ➜  OK
fv = = 53.04 psi
 fv = 53.04 psi < Fvx' = 180.00 psi  (CSI = 0.29)   ➜  OK
5/23/2022 5
ΔLL = = 0.09 in.
(L/d)LL = 114.00 / 0.09 = 1231
 ΔLL = 0.09 in = L/1231 < L/180   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 114.00 / 0.12 = 953
 ΔTL = 0.12 in = L/953 < L/120   ➜  OK
fc⊥ = = 111.9 psi
 fc⊥ = 111.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.18)   ➜  OK
5/23/2022 6
