Beam Design - Leas Deck
Design Span (L): 15.25 ft.
Clear Span: 15.00 ft.
Total Span: 15.50 ft.
Quantity (N): 4
Live Load: 200 plf
Dead Load: 175 plf
Selfweight: 253.5 lbs
Dist. Selfweight: 16.63 plf
Total Weight: 257.7 lbs
Beam Design 2022A322
5/23/2022 1
5/23/2022 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (183.00 + 3)] x (12 in./ft.)3 = 7.27 ft3
Volumespan = N[A x L] = 4 x [16.88 x 183.00] x (12 in./ft.)3 = 7.15 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 7.27 = 257.7 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 7.15 = 253.5 lbs
Distributed Self Weight (ws) = = 16.63 plf
200 plf
175 plf
ws = 16.63 plf
15.25 ft.
15.00 ft.
15.50 ft.
3035.10 lbs
3035.10 lbs
5/23/2022 3
fb = = 1079.4 psi
 fb = 1079.4 psi > Fbx' = 1035.0 psi  (CSI = 1.04)   ➜  NG
5/23/2022 4
fv* = = 58.20 psi
 fv* = 58.20 psi < Fvx' = 200.79 psi  (CSI = 0.29)   ➜  OK
fv = = 66.36 psi
 fv = 66.36 psi < Fvx' = 200.79 psi  (CSI = 0.33)   ➜  OK
5/23/2022 5
ΔLL = = 0.24 in.
(L/d)LL = 183.00 / 0.24 = 771
 ΔLL = 0.24 in = L/771 < L/180   ➜  OK
ΔTL = = 0.46 in.
(L/d)TL = 183.00 / 0.46 = 394
 ΔTL = 0.46 in = L/394 < L/120   ➜  OK
fc⊥ = = 168.6 psi
 fc⊥ = 168.6 psi < Fc⊥x' = 418.75 psi  (CSI = 0.40)   ➜  OK
5/23/2022 6
