Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 51 plf
Dead Load: 2 plf
Selfweight: 71.0 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 72.3 lbs
Beam Design 2022A32
1/16/2022 1
Beam Design 2022A32
1/16/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (165.00 + 3)] x (12 in./ft.)3 = 2.11 ft3
Volumespan = N[A x L] = 2 x [10.88 x 165.00] x (12 in./ft.)3 = 2.08 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.11 = 72.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.08 = 71.0 lbs
51 plf
2 plf
ws = 5.17 plf
13.75 ft.
13.50 ft.
407.16 lbs
407.16 lbs
Beam Design 2022A32
1/16/2022 3
fb = = 627.7 psi
 fb = 627.7 psi < Fbx' = 1242.0 psi  (CSI = 0.51)   ➜  OK
Beam Design 2022A32
1/16/2022 4
fv* = = 25.16 psi
 fv* = 25.16 psi < Fvx' = 207.00 psi  (CSI = 0.12)   ➜  OK
fv = = 27.58 psi
 fv = 27.58 psi < Fvx' = 207.00 psi  (CSI = 0.13)   ➜  OK
Beam Design 2022A32
1/16/2022 5
ΔLL = = 0.27 in.
(L/d)LL = 165.00 / 0.27 = 613
 ΔLL = 0.27 in = L/613 < L/360   ➜  OK
ΔTL = = 0.31 in.
(L/d)TL = 165.00 / 0.31 = 538
 ΔTL = 0.31 in = L/538 < L/240   ➜  OK
fc⊥ = = 45.2 psi
 fc⊥ = 45.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.07)   ➜  OK
Beam Design 2022A32
1/16/2022 6
