Beam Design - Beam
Grade: SPF SS
Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Live Load: 150 plf
Dead Load: 5 plf
Selfweight: 20.0 lbs
Dist. Selfweight: 2.29 plf
Total Weight: 20.6 lbs
Beam Design C B Tent Platform
5/22/2022 1
5/22/2022 2
= 30.34 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (105.00 + 3)] x (12 in./ft.)3 = 0.68 ft3
Volumespan = N[A x L] = 1 x [10.88 x 105.00] x (12 in./ft.)3 = 0.66 ft3
Total Weight (WT) = ρw x Volumetotal = 30.34 x 0.68 = 20.6 lbs
Self Weight (WS) = ρw x Volumespan = 30.34 x 0.66 = 20.0 lbs
Distributed Self Weight (ws) = = 2.29 plf
150 plf
5 plf
ws = 2.29 plf
8.75 ft.
8.50 ft.
9.00 ft.
707.81 lbs
707.81 lbs
5/22/2022 3
Fbx' = (1250)(1.15)(0.85)(1)(1)(1.2)(1)(1) = 1466.3 psi
fb = = 1374.7 psi
 fb = 1374.7 psi < Fbx' = 1466.3 psi  (CSI = 0.94)   ➜  OK
5/22/2022 4
Fvx' = (135)(1.15)(0.97)(1)(1) = 150.59 psi
fv* = = 81.81 psi
 fv* = 81.81 psi < Fvx' = 150.59 psi  (CSI = 0.54)   ➜  OK
fv = = 94.92 psi
 fv = 94.92 psi < Fvx' = 150.59 psi  (CSI = 0.63)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1500000(0.9)(1)(1) = 1350000 psi
5/22/2022 5
ΔLL = = 0.31 in.
(L/d)LL = 105.00 / 0.31 = 341
 ΔLL = 0.31 in = L/341 > L/360   ➜  NG
ΔTL = = 0.32 in.
(L/d)TL = 105.00 / 0.32 = 325
 ΔTL = 0.32 in = L/325 < L/240   ➜  OK
fc⊥ = = 157.3 psi
 fc⊥ = 157.3 psi < Fc⊥x' = 284.75 psi  (CSI = 0.55)   ➜  OK
5/22/2022 6
