Beam Design - Beam
Grade: SPF SS
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 150 plf
Dead Load: 10 plf
Selfweight: 17.8 lbs
Dist. Selfweight: 2.29 plf
Total Weight: 18.3 lbs
Beam Design C B Tent Platform
5/22/2022 1
5/22/2022 2
= 30.34 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (93.00 + 3)] x (12 in./ft.)3 = 0.60 ft3
Volumespan = N[A x L] = 1 x [10.88 x 93.00] x (12 in./ft.)3 = 0.59 ft3
Total Weight (WT) = ρw x Volumetotal = 30.34 x 0.60 = 18.3 lbs
Self Weight (WS) = ρw x Volumespan = 30.34 x 0.59 = 17.8 lbs
Distributed Self Weight (ws) = = 2.29 plf
150 plf
10 plf
ws = 2.29 plf
7.75 ft.
7.50 ft.
649.16 lbs
649.16 lbs
5/22/2022 3
Fbx' = (1250)(1.15)(0.85)(1)(1)(1.2)(1)(1) = 1466.3 psi
fb = = 1112.7 psi
 fb = 1112.7 psi < Fbx' = 1466.3 psi  (CSI = 0.76)   ➜  OK
5/22/2022 4
Fvx' = (135)(1.15)(0.97)(1)(1) = 150.59 psi
fv* = = 73.22 psi
 fv* = 73.22 psi < Fvx' = 150.59 psi  (CSI = 0.49)   ➜  OK
fv = = 86.74 psi
 fv = 86.74 psi < Fvx' = 150.59 psi  (CSI = 0.58)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1500000(0.9)(1)(1) = 1350000 psi
5/22/2022 5
ΔLL = = 0.19 in.
(L/d)LL = 93.00 / 0.19 = 491
 ΔLL = 0.19 in = L/491 < L/360   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 93.00 / 0.20 = 454
 ΔTL = 0.20 in = L/454 < L/240   ➜  OK
fc⊥ = = 144.3 psi
 fc⊥ = 144.3 psi < Fc⊥x' = 284.75 psi  (CSI = 0.51)   ➜  OK
5/22/2022 6
