Grade: SPF SS
Design Span (L): 15.42 ft.
Clear Span: 15.08 ft.
Total Span: 15.75 ft.
Bearing (lb): 4 in.
Quantity (N): 4
Live Load: 280 plf
Dead Load: 140 plf
Selfweight: 210.3 lbs
Dist. Selfweight: 13.64 plf
Total Weight: 214.8 lbs
Beam Design 2022A317
5/19/2022 1
5/19/2022 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (185.00 + 4)] x (12 in./ft.)3 = 7.38 ft3
Volumespan = N[A x L] = 4 x [16.88 x 185.00] x (12 in./ft.)3 = 7.23 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 7.38 = 214.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 7.23 = 210.3 lbs
Distributed Self Weight (ws) = = 13.64 plf
280 plf
140 plf
ws = 13.64 plf
15.42 ft.
15.08 ft.
15.75 ft.
3414.98 lbs
3414.98 lbs
5/19/2022 3
Fbx' = (1250)(1.00)(1)(1)(1)(1)(1)(1) = 1250.0 psi
fb = = 1221.6 psi
 fb = 1221.6 psi < Fbx' = 1250.0 psi  (CSI = 0.98)   ➜  OK
5/19/2022 4
fv* = = 65.25 psi
 fv* = 65.25 psi < Fvx' = 135.00 psi  (CSI = 0.48)   ➜  OK
fv = = 74.28 psi
 fv = 74.28 psi < Fvx' = 135.00 psi  (CSI = 0.55)   ➜  OK
5/19/2022 5
ΔLL = = 0.33 in.
(L/d)LL = 185.00 / 0.33 = 555
 ΔLL = 0.33 in = L/555 < L/180   ➜  OK
ΔTL = = 0.52 in.
(L/d)TL = 185.00 / 0.52 = 358
 ΔTL = 0.52 in = L/358 < L/120   ➜  OK
fc⊥ = = 142.3 psi
 fc⊥ = 142.3 psi < Fc⊥x' = 425.00 psi  (CSI = 0.33)   ➜  OK
5/19/2022 6
