Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 55.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 56.1 lbs
Beam Design 2022A316
5/18/2022 1
5/18/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (165.00 + 3)] x (12 in./ft.)3 = 1.64 ft3
Volumespan = N[A x L] = 1 x [16.88 x 165.00] x (12 in./ft.)3 = 1.61 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.64 = 56.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.61 = 55.1 lbs
40 plf
10 plf
ws = 4.01 plf
13.75 ft.
13.50 ft.
378.06 lbs
378.06 lbs
5/18/2022 3
fb = = 484.1 psi
 fb = 484.1 psi < Fbx' = 1035.0 psi  (CSI = 0.47)   ➜  OK
5/18/2022 4
fv* = = 28.50 psi
 fv* = 28.50 psi < Fvx' = 207.00 psi  (CSI = 0.14)   ➜  OK
fv = = 33.01 psi
 fv = 33.01 psi < Fvx' = 207.00 psi  (CSI = 0.16)   ➜  OK
5/18/2022 5
ΔLL = = 0.11 in.
(L/d)LL = 165.00 / 0.11 = 1461
 ΔLL = 0.11 in = L/1461 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 165.00 / 0.15 = 1082
 ΔTL = 0.15 in = L/1082 < L/240   ➜  OK
fc⊥ = = 84.0 psi
 fc⊥ = 84.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.13)   ➜  OK
5/18/2022 6
