Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 63.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 64.1 lbs
Beam Design 2022A313
5/18/2022 1
5/18/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (189.00 + 3)] x (12 in./ft.)3 = 1.88 ft3
Volumespan = N[A x L] = 1 x [16.88 x 189.00] x (12 in./ft.)3 = 1.85 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.88 = 64.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.85 = 63.1 lbs
40 plf
10 plf
ws = 4.01 plf
15.75 ft.
15.50 ft.
432.07 lbs
432.07 lbs
5/18/2022 3
fb = = 635.1 psi
 fb = 635.1 psi < Fbx' = 1035.0 psi  (CSI = 0.61)   ➜  OK
5/18/2022 4
fv* = = 33.31 psi
 fv* = 33.31 psi < Fvx' = 207.00 psi  (CSI = 0.16)   ➜  OK
fv = = 37.81 psi
 fv = 37.81 psi < Fvx' = 207.00 psi  (CSI = 0.18)   ➜  OK
5/18/2022 5
ΔLL = = 0.19 in.
(L/d)LL = 189.00 / 0.19 = 972
 ΔLL = 0.19 in = L/972 < L/180   ➜  OK
ΔTL = = 0.26 in.
(L/d)TL = 189.00 / 0.26 = 720
 ΔTL = 0.26 in = L/720 < L/120   ➜  OK
fc⊥ = = 96.0 psi
 fc⊥ = 96.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.15)   ➜  OK
5/18/2022 6
