Grade: SP No.1
Design Span (L): 23.54 ft.
Clear Span: 23.08 ft.
Total Span: 24.00 ft.
Bearing (lb): 5.5 in.
Live Load: 120 plf
Dead Load: 40 plf
Selfweight: 66.4 lbs
Dist. Selfweight: 2.82 plf
Total Weight: 67.7 lbs
Beam Design 2022A312
5/17/2022 1
SP No.1 1250 800 175 565 1500 1600000 580000 0.55
5/17/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (282.50 + 5.5)] x (12 in./ft.)3 = 1.81 ft3
Volumespan = N[A x L] = 1 x [10.88 x 282.50] x (12 in./ft.)3 = 1.78 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.81 = 67.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.78 = 66.4 lbs
Distributed Self Weight (ws) = = 2.82 plf
120 plf
40 plf
ws = 2.82 plf
23.54 ft.
23.08 ft.
24.00 ft.
1953.86 lbs
1953.86 lbs
5/17/2022 3
Fbx' = (1250)(1.00)(1)(1)(1)(1)(1)(1) = 1250.0 psi
fb = = 10300.7 psi
 fb = 10300.7 psi > Fbx' = 1250.0 psi  (CSI = 8.24)   ➜  NG
5/17/2022 4
fv* = = 250.78 psi
 fv* = 250.78 psi > Fvx' = 175.00 psi  (CSI = 1.43)   ➜  NG
fv = = 264.35 psi
 fv = 264.35 psi > Fvx' = 175.00 psi  (CSI = 1.51)   ➜  NG
5/17/2022 5
ΔLL = = 10.88 in.
(L/d)LL = 282.50 / 10.88 = 26
 ΔLL = 10.88 in = L/26 > L/360   ➜  NG
ΔTL = = 14.76 in.
(L/d)TL = 282.50 / 14.76 = 19
 ΔTL = 14.76 in = L/19 > L/240   ➜  NG
fc⊥ = = 236.8 psi
 fc⊥ = 236.8 psi < Fc⊥x' = 565.00 psi  (CSI = 0.42)   ➜  OK
5/17/2022 6
