Size: 3.125 x 18
Design Span (L): 17.33 ft.
Clear Span: 16.67 ft.
Total Span: 18.00 ft.
Bearing (lb): 8 in.
Live Load: 440 plf
Dead Load: 415 plf
Selfweight: 228.6 lbs
Dist. Selfweight: 13.19 plf
Total Weight: 237.4 lbs
Beam Design 2022A311
5/16/2022 1
b = 3.125 in.
d = 18.000 in.
A = 3.125 x 18.000 = 56.25 in.2
Sx = (3.125)(18.000)2/6 = 168.75 in.3
Sy = (3.125)2(18.000)/6 = 29.30 in.3
Ix = (3.125)(18.000)3/12 = 1518.75 in.4
Iy = (3.125)3(18.000)/12 = 45.78 in.4
5/16/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [56.25 x (208.00 + 8)] x (12 in./ft.)3 = 7.03 ft3
Volumespan = N[A x L] = 1 x [56.25 x 208.00] x (12 in./ft.)3 = 6.77 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.03 = 237.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.77 = 228.6 lbs
Distributed Self Weight (ws) = = 13.19 plf
440 plf
415 plf
  ws = 13.19 plf
17.33 ft.
16.67 ft.
18.00 ft.
7813.55 lbs
7813.55 lbs
5/16/2022 3
fb = = 2318.5 psi
 fb = 2318.5 psi < Fbx' = 2400.0 psi  (CSI = 0.97)   ➜  OK
5/16/2022 4
fv* = = 165.92 psi
 fv* = 165.92 psi < Fvx' = 265.00 psi  (CSI = 0.63)   ➜  OK
fv = = 200.64 psi
 fv = 200.64 psi < Fvx' = 265.00 psi  (CSI = 0.76)   ➜  OK
5/16/2022 5
ΔLL = = 0.33 in.
(L/d)LL = 208.00 / 0.33 = 636
 ΔLL = 0.33 in = L/636 < L/360   ➜  OK
ΔTL = = 0.64 in.
(L/d)TL = 208.00 / 0.64 = 322
 ΔTL = 0.64 in = L/322 < L/240   ➜  OK
Ab = b x lb = 3.125 x 8 = 25.00 in2
fc⊥ = = 312.5 psi
 fc⊥ = 312.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.48)   ➜  OK
5/16/2022 6
