Size: 3.125 x 18
Design Span (L): 19.33 ft.
Clear Span: 18.67 ft.
Total Span: 20.00 ft.
Bearing (lb): 8 in.
Live Load: 440 plf
Dead Load: 275 plf
Selfweight: 255.0 lbs
Dist. Selfweight: 13.19 plf
Total Weight: 263.8 lbs
Beam Design 2022A310
5/16/2022 1
b = 3.125 in.
d = 18.000 in.
A = 3.125 x 18.000 = 56.25 in.2
Sx = (3.125)(18.000)2/6 = 168.75 in.3
Sy = (3.125)2(18.000)/6 = 29.30 in.3
Ix = (3.125)(18.000)3/12 = 1518.75 in.4
Iy = (3.125)3(18.000)/12 = 45.78 in.4
5/16/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [56.25 x (232.00 + 8)] x (12 in./ft.)3 = 7.81 ft3
Volumespan = N[A x L] = 1 x [56.25 x 232.00] x (12 in./ft.)3 = 7.55 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.81 = 263.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.55 = 255.0 lbs
Distributed Self Weight (ws) = = 13.19 plf
440 plf
275 plf
  ws = 13.19 plf
19.33 ft.
18.67 ft.
7281.76 lbs
7281.76 lbs
5/16/2022 3
fb = = 2419.3 psi
 fb = 2419.3 psi > Fbx' = 2400.0 psi  (CSI = 1.01)   ➜  NG
5/16/2022 4
fv* = = 158.58 psi
 fv* = 158.58 psi < Fvx' = 265.00 psi  (CSI = 0.60)   ➜  OK
fv = = 187.71 psi
 fv = 187.71 psi < Fvx' = 265.00 psi  (CSI = 0.71)   ➜  OK
5/16/2022 5
ΔLL = = 0.51 in.
(L/d)LL = 232.00 / 0.51 = 459
 ΔLL = 0.51 in = L/459 < L/360   ➜  OK
ΔTL = = 0.84 in.
(L/d)TL = 232.00 / 0.84 = 277
 ΔTL = 0.84 in = L/277 < L/240   ➜  OK
Ab = b x lb = 3.125 x 8 = 25.00 in2
fc⊥ = = 291.3 psi
 fc⊥ = 291.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.45)   ➜  OK
5/16/2022 6
