Size: 3.5 x 19.5
Design Span (L): 17.33 ft.
Clear Span: 16.67 ft.
Total Span: 18.00 ft.
Bearing (lb): 8 in.
Live Load: 440 plf
Dead Load: 585 plf
Selfweight: 277.4 lbs
Dist. Selfweight: 16.00 plf
Total Weight: 288.0 lbs
Beam Design 2022A309
5/16/2022 1
d = 19.500 in.
A = 3.500 x 19.500 = 68.25 in.2
Sx = (3.500)(19.500)2/6 = 221.81 in.3
Sy = (3.500)2(19.500)/6 = 39.81 in.3
Ix = (3.500)(19.500)3/12 = 2162.67 in.4
Iy = (3.500)3(19.500)/12 = 69.67 in.4
5/16/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [68.25 x (208.00 + 8)] x (12 in./ft.)3 = 8.53 ft3
Volumespan = N[A x L] = 1 x [68.25 x 208.00] x (12 in./ft.)3 = 8.22 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.53 = 288.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.22 = 277.4 lbs
Distributed Self Weight (ws) = = 16.00 plf
440 plf
585 plf
  ws = 16.00 plf
17.33 ft.
16.67 ft.
18.00 ft.
9368.84 lbs
9368.84 lbs
5/16/2022 3
fb = = 2115.0 psi
 fb = 2115.0 psi < Fbx' = 2400.0 psi  (CSI = 0.88)   ➜  OK
5/16/2022 4
fv* = = 161.10 psi
 fv* = 161.10 psi < Fvx' = 265.00 psi  (CSI = 0.61)   ➜  OK
fv = = 198.28 psi
 fv = 198.28 psi < Fvx' = 265.00 psi  (CSI = 0.75)   ➜  OK
5/16/2022 5
ΔLL = = 0.23 in.
(L/d)LL = 208.00 / 0.23 = 906
 ΔLL = 0.23 in = L/906 < L/360   ➜  OK
ΔTL = = 0.54 in.
(L/d)TL = 208.00 / 0.54 = 383
 ΔTL = 0.54 in = L/383 < L/240   ➜  OK
fc⊥ = = 334.6 psi
 fc⊥ = 334.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.51)   ➜  OK
5/16/2022 6
