Size: 3.5 x 22.5
Design Span (L): 19.33 ft.
Clear Span: 18.67 ft.
Total Span: 20.00 ft.
Bearing (lb): 8 in.
Live Load: 440 plf
Dead Load: 585 plf
Selfweight: 356.9 lbs
Dist. Selfweight: 18.46 plf
Total Weight: 369.3 lbs
CV Volume Factor 0.984b - - - - -
Beam Design 2022A308
5/16/2022 1
d = 22.500 in.
A = 3.500 x 22.500 = 78.75 in.2
Sx = (3.500)(22.500)2/6 = 295.31 in.3
Sy = (3.500)2(22.500)/6 = 45.94 in.3
Ix = (3.500)(22.500)3/12 = 3322.27 in.4
Iy = (3.500)3(22.500)/12 = 80.39 in.4
5/16/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [78.75 x (232.00 + 8)] x (12 in./ft.)3 = 10.94 ft3
Volumespan = N[A x L] = 1 x [78.75 x 232.00] x (12 in./ft.)3 = 10.57 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 10.94 = 369.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 10.57 = 356.9 lbs
Distributed Self Weight (ws) = = 18.46 plf
440 plf
585 plf
  ws = 18.46 plf
19.33 ft.
18.67 ft.
10434.46 lbs
10434.46 lbs
5/16/2022 3
CV = = 0.984
CV = 0.984 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.984) = 2360.8 psi
fb = = 1981.0 psi
 fb = 1981.0 psi < Fbx' = 2360.8 psi  (CSI = 0.84)   ➜  OK
5/16/2022 4
fv* = = 154.86 psi
 fv* = 154.86 psi < Fvx' = 265.00 psi  (CSI = 0.58)   ➜  OK
fv = = 192.13 psi
 fv = 192.13 psi < Fvx' = 265.00 psi  (CSI = 0.73)   ➜  OK
5/16/2022 5
ΔLL = = 0.23 in.
(L/d)LL = 232.00 / 0.23 = 1003
 ΔLL = 0.23 in = L/1003 < L/360   ➜  OK
ΔTL = = 0.55 in.
(L/d)TL = 232.00 / 0.55 = 423
 ΔTL = 0.55 in = L/423 < L/240   ➜  OK
fc⊥ = = 372.7 psi
 fc⊥ = 372.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.57)   ➜  OK
5/16/2022 6
