Size: 3.5 x 21
Design Span (L): 19.33 ft.
Clear Span: 18.67 ft.
Total Span: 20.00 ft.
Bearing (lb): 8 in.
Live Load: 440 plf
Dead Load: 585 plf
Selfweight: 333.2 lbs
Dist. Selfweight: 17.23 plf
Total Weight: 344.6 lbs
CV Volume Factor 0.990b - - - - -
Beam Design 2022A307
5/16/2022 1
d = 21.000 in.
A = 3.500 x 21.000 = 73.50 in.2
Sx = (3.500)(21.000)2/6 = 257.25 in.3
Sy = (3.500)2(21.000)/6 = 42.88 in.3
Ix = (3.500)(21.000)3/12 = 2701.13 in.4
Iy = (3.500)3(21.000)/12 = 75.03 in.4
5/16/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [73.50 x (232.00 + 8)] x (12 in./ft.)3 = 10.21 ft3
Volumespan = N[A x L] = 1 x [73.50 x 232.00] x (12 in./ft.)3 = 9.87 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 10.21 = 344.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.87 = 333.2 lbs
Distributed Self Weight (ws) = = 17.23 plf
440 plf
585 plf
  ws = 17.23 plf
19.33 ft.
18.67 ft.
10422.15 lbs
10422.15 lbs
5/16/2022 3
CV = = 0.990
CV = 0.990 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.990) = 2377.2 psi
fb = = 2271.4 psi
 fb = 2271.4 psi < Fbx' = 2377.2 psi  (CSI = 0.96)   ➜  OK
5/16/2022 4
fv* = = 168.38 psi
 fv* = 168.38 psi < Fvx' = 265.00 psi  (CSI = 0.64)   ➜  OK
fv = = 205.61 psi
 fv = 205.61 psi < Fvx' = 265.00 psi  (CSI = 0.78)   ➜  OK
5/16/2022 5
ΔLL = = 0.28 in.
(L/d)LL = 232.00 / 0.28 = 816
 ΔLL = 0.28 in = L/816 < L/360   ➜  OK
ΔTL = = 0.67 in.
(L/d)TL = 232.00 / 0.67 = 344
 ΔTL = 0.67 in = L/344 < L/240   ➜  OK
fc⊥ = = 372.2 psi
 fc⊥ = 372.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.57)   ➜  OK
5/16/2022 6
