Beam Design - Deck Beam Calculations
Grade: DF No.1
Size: 4 x 10
Design Span (L): 7.50 ft.
Clear Span: 7.25 ft.
Total Span: 7.75 ft.
Live Load: 464 plf
Dead Load: 80 plf
Selfweight: 59.8 lbs
Dist. Selfweight: 7.97 plf
Total Weight: 61.8 lbs
Incised Lumber: Yes
Notes: LL 58 psf (snow)
DL 10 psf
Grade no. 1
CL Beam Stability Factor 0.990 - - - - -
Beam Design c c Speckled Rd 5-7-2022
5/8/2022 1
5/8/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (90.00 + 3)] x (12 in./ft.)3 = 1.74 ft3
Volumespan = N[A x L] = 1 x [32.38 x 90.00] x (12 in./ft.)3 = 1.69 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 1.74 = 61.8 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 1.69 = 59.8 lbs
Distributed Self Weight (ws) = = 7.97 plf
464 plf
80 plf
ws = 7.97 plf
7.50 ft.
7.25 ft.
7.75 ft.
2138.90 lbs
2138.90 lbs
5/8/2022 3
lu = Unbraced Length = 7.500 ft.
lu/d = = 9.73
le = 1.63lu + 3d = 1.63(90.0) + 3(9.25) = 174.45 in. = 14.54 ft.  (NDS Table 3.3.3)
Rb = = 11.48
 Rb = 11.48 < 50   ➜  OK
5/8/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 620000(0.9)(1)(0.95) = 530100 psi
FbE = = 4829.06 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(1.00)(0.85)(1)(1.2)(0.8)(1) = 816.00 psi
CL =   = 0.990
Fbx' = (1000)(1.00)(0.85)(1)(0.990)(1.2)(0.8)(1) = 807.9 psi
fb = = 933.1 psi
 fb = 933.1 psi > Fbx' = 807.9 psi  (CSI = 1.16)   ➜  NG
Fvx' = (180)(1.00)(0.97)(1)(0.8) = 139.68 psi
fv* = = 76.19 psi
 fv* = 76.19 psi < Fvx' = 139.68 psi  (CSI = 0.55)   ➜  OK
fv = = 95.90 psi
 fv = 95.90 psi < Fvx' = 139.68 psi  (CSI = 0.69)   ➜  OK
5/8/2022 5
Ex' = Ex(CM)(Ct)(Ci) = 1700000(0.9)(1)(0.95) = 1453500 psi
ΔLL = = 0.10 in.
(L/d)LL = 90.00 / 0.10 = 914
 ΔLL = 0.10 in = L/914 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 90.00 / 0.12 = 768
 ΔTL = 0.12 in = L/768 < L/240   ➜  OK
fc⊥ = = 203.7 psi
 fc⊥ = 203.7 psi < Fc⊥x' = 418.75 psi  (CSI = 0.49)   ➜  OK
5/8/2022 6
