Beam Design - Deck
Size: 4 x 10
Design Span (L): 7.50 ft.
Clear Span: 7.25 ft.
Total Span: 7.75 ft.
Live Load: 560 plf
Dead Load: 80 plf
Selfweight: 179.4 lbs
Dist. Selfweight: 23.92 plf
Total Weight: 185.4 lbs
Incised Lumber: Yes
Beam Design c c 1
5/8/2022 1
Beam Design c c 1
5/8/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [32.38 x (90.00 + 3)] x (12 in./ft.)3 = 5.23 ft3
Volumespan = N[A x L] = 3 x [32.38 x 90.00] x (12 in./ft.)3 = 5.06 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 5.23 = 185.4 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 5.06 = 179.4 lbs
Distributed Self Weight (ws) = = 23.92 plf
560 plf
80 plf
ws = 23.92 plf
7.50 ft.
7.25 ft.
7.75 ft.
2572.70 lbs
2572.70 lbs
Beam Design c c 1
5/8/2022 3
Fbx' = (900)(1.00)(1)(1)(1)(1.2)(0.8)(1) = 864.0 psi
fb = = 374.1 psi
 fb = 374.1 psi < Fbx' = 864.0 psi  (CSI = 0.43)   ➜  OK
Beam Design c c 1
5/8/2022 4
Fvx' = (180)(1.00)(0.97)(1)(0.8) = 139.68 psi
fv* = = 30.55 psi
 fv* = 30.55 psi < Fvx' = 139.68 psi  (CSI = 0.22)   ➜  OK
fv = = 38.45 psi
 fv = 38.45 psi < Fvx' = 139.68 psi  (CSI = 0.28)   ➜  OK
Beam Design c c 1
5/8/2022 5
ΔLL = = 0.04 in.
(L/d)LL = 90.00 / 0.04 = 2139
 ΔLL = 0.04 in = L/2139 < L/360   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 90.00 / 0.05 = 1804
 ΔTL = 0.05 in = L/1804 < L/240   ➜  OK
fc⊥ = = 81.7 psi
 fc⊥ = 81.7 psi < Fc⊥x' = 418.75 psi  (CSI = 0.20)   ➜  OK
Beam Design c c 1
5/8/2022 6
