Size: 8.75 x 27
Design Span (L): 39.50 ft.
Clear Span: 39.00 ft.
Total Span: 40.00 ft.
Live Load: 100 lbs
Dead Load: 75 lbs
Selfweight: 2187.9 lbs
Dist. Selfweight: 55.39 plf
Total Weight: 2215.6 lbs
Orientation: Horizontal
Cfu Flat Use Factor 1.036c - - - - -
Beam Design 2022A300
5/5/2022 1
b = 8.750 in.
d = 27.000 in.
A = 8.750 x 27.000 = 236.25 in.2
Sx = (8.750)(27.000)2/6 = 1063.13 in.3
Sy = (8.750)2(27.000)/6 = 344.53 in.3
Ix = (8.750)(27.000)3/12 = 14352.19 in.4
Iy = (8.750)3(27.000)/12 = 1507.32 in.4
5/5/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [236.25 x (474.00 + 6)] x (12 in./ft.)3 = 65.63 ft3
Volumespan = N[A x L] = 1 x [236.25 x 474.00] x (12 in./ft.)3 = 64.80 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 65.63 = 2215.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 64.80 = 2187.9 lbs
Distributed Self Weight (ws) = = 55.39 plf
100 lbs
75 lbs
  ws = 55.39 plf
39.50 ft.
39.00 ft.
40.00 ft.
1195.29 lbs
1195.29 lbs
5/5/2022 3
Cfu = = 1.036
Fby' = (1450)(1.15)(1)(1)(1)(1.036) = 1727.1 psi
fb = = 436.4 psi
 fb = 436.4 psi < Fby' = 1727.1 psi  (CSI = 0.25)   ➜  OK
5/5/2022 4
Fvy' = (230)(1.15)(1)(1) = 304.75 psi
fv* = = 7.24 psi
 fv* = 7.24 psi < Fvy' = 264.50 psi  (CSI = 0.03)   ➜  OK
fv = = 7.50 psi
 fv = 7.50 psi < Fvy' = 264.50 psi  (CSI = 0.03)   ➜  OK
Ey' = Ey(CM)(Ct) = 1600000(1)(1) = 1600000 psi
5/5/2022 5
ΔLL =   =   = 0.09 in.
(L/d)LL = 474.00 / 0.09 = 5152
 ΔLL = 0.09 in = L/5152 < L/360   ➜  OK
ΔTL =   =   = 1.42 in.
(L/d)TL = 474.00 / 1.42 = 334
 ΔTL = 1.42 in = L/334 < L/240   ➜  OK
Fc⊥y' = (560)(1)(1) = 560.00 psi
Ab = d x lb = 27 x 6 = 162.00 in2
fc⊥ = = 7.4 psi
 fc⊥ = 7.4 psi < Fc⊥y' = 560.00 psi  (CSI = 0.01)   ➜  OK
5/5/2022 6
