Grade: SP No.1
Design Span (L): 15.88 ft.
Clear Span: 15.75 ft.
Total Span: 16.00 ft.
Bearing (lb): 1.5 in.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 69.4 lbs
Dist. Selfweight: 4.37 plf
Total Weight: 70.0 lbs
Beam Design 2022A297
5/3/2022 1
5/3/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (190.50 + 1.5)] x (12 in./ft.)3 = 1.88 ft3
Volumespan = N[A x L] = 1 x [16.88 x 190.50] x (12 in./ft.)3 = 1.86 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.88 = 70.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.86 = 69.4 lbs
40 plf
10 plf
ws = 4.37 plf
15.88 ft.
15.75 ft.
435.00 lbs
435.00 lbs
5/3/2022 3
fb = = 649.6 psi
 fb = 649.6 psi < Fbx' = 1150.0 psi  (CSI = 0.56)   ➜  OK
5/3/2022 4
fv* = = 33.83 psi
 fv* = 33.83 psi < Fvx' = 201.25 psi  (CSI = 0.17)   ➜  OK
fv = = 38.36 psi
 fv = 38.36 psi < Fvx' = 201.25 psi  (CSI = 0.19)   ➜  OK
5/3/2022 5
ΔLL = = 0.20 in.
(L/d)LL = 190.50 / 0.20 = 949
 ΔLL = 0.20 in = L/949 < L/180   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 190.50 / 0.27 = 698
 ΔTL = 0.27 in = L/698 < L/120   ➜  OK
fc⊥ = = 193.3 psi
 fc⊥ = 193.3 psi < Fc⊥x' = 565.00 psi  (CSI = 0.34)   ➜  OK
5/3/2022 6
