Size: 4 x 12
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Selfweight: 128.6 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 130.9 lbs
CL Beam Stability Factor 0.963 - - - - -
CF Size Factor 1.1 1 - 1 - -
Beam Design 2022A295
4/30/2022 1
4/30/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (165.00 + 3)] x (12 in./ft.)3 = 3.83 ft3
Volumespan = N[A x L] = 1 x [39.38 x 165.00] x (12 in./ft.)3 = 3.76 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.83 = 130.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.76 = 128.6 lbs
ws = 9.35 plf
13.75 ft.
13.50 ft.
1290.47 lbs
1290.47 lbs
4/30/2022 3
lu = Unbraced Length = 13.750 ft.
lu/d = = 14.67
le = 1.63lu + 3d = 1.63(165.0) + 3(11.25) = 302.70 in. = 25.22 ft.  (NDS Table 3.3.3)
Rb = = 16.67
 Rb = 16.67 < 50   ➜  OK
4/30/2022 4
FbE = = 2503.69 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1.1)(1)(1) = 1138.50 psi
CL =   = 0.963
Fbx' = (900)(1.15)(1)(1)(0.963)(1.1)(1)(1) = 1095.8 psi
fb = = 708.1 psi
 fb = 708.1 psi < Fbx' = 1095.8 psi  (CSI = 0.65)   ➜  OK
fv* = = 41.70 psi
 fv* = 41.70 psi < Fvx' = 207.00 psi  (CSI = 0.20)   ➜  OK
fv = = 48.28 psi
 fv = 48.28 psi < Fvx' = 207.00 psi  (CSI = 0.23)   ➜  OK
4/30/2022 5
ΔLL = = 0.12 in.
(L/d)LL = 165.00 / 0.12 = 1363
 ΔLL = 0.12 in = L/1363 < L/180   ➜  OK
ΔTL = = 0.22 in.
(L/d)TL = 165.00 / 0.22 = 739
 ΔTL = 0.22 in = L/739 < L/120   ➜  OK
fc⊥ = = 122.9 psi
 fc⊥ = 122.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.20)   ➜  OK
4/30/2022 6
