Grade: SPF SS
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Quantity (N): 5
Live Load: plf
Dead Load: 110 plf
Selfweight: 47.9 lbs
Dist. Selfweight: 8.34 plf
Total Weight: 50.0 lbs
Beam Design The Stable
1/16/2022 1
1/16/2022 2
Volumetotal = N[A x (L + lb)] = 5 x [8.25 x (69.00 + 3)] x (12 in./ft.)3 = 1.72 ft3
Volumespan = N[A x L] = 5 x [8.25 x 69.00] x (12 in./ft.)3 = 1.65 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.72 = 50.0 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.65 = 47.9 lbs
Distributed Self Weight (ws) = = 8.34 plf
plf
110 plf
ws = 8.34 plf
5.75 ft.
5.50 ft.
355.01 lbs
355.01 lbs
1/16/2022 3
Fbx' = (1250)(1.00)(1)(1)(1)(1.3)(1)(1) = 1625.0 psi
fb = = 155.2 psi
 fb = 155.2 psi < Fbx' = 1625.0 psi  (CSI = 0.10)   ➜  OK
1/16/2022 4
fv* = = 10.40 psi
 fv* = 10.40 psi < Fvx' = 135.00 psi  (CSI = 0.08)   ➜  OK
fv = = 12.37 psi
 fv = 12.37 psi < Fvx' = 135.00 psi  (CSI = 0.09)   ➜  OK
1/16/2022 5
ΔLL = = 0.00 in.
(L/d)LL = 69.00 / 0.00 = ∞
ΔTL = = 0.02 in.
(L/d)TL = 69.00 / 0.02 = 3698
 ΔTL = 0.02 in = L/3698 < L/120   ➜  OK
fc⊥ = = 15.8 psi
 fc⊥ = 15.8 psi < Fc⊥x' = 425.00 psi  (CSI = 0.04)   ➜  OK
1/16/2022 6
