Grade: SPF No.2
Design Span (L): 6.71 ft.
Clear Span: 6.42 ft.
Total Span: 7.00 ft.
Bearing (lb): 3.5 in.
Selfweight: 29.5 lbs
Dist. Selfweight: 4.39 plf
Total Weight: 30.8 lbs
Load Duration: 1.25
Beam Design 2022A284
4/27/2022 1
4/27/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (80.50 + 3.5)] x (12 in./ft.)3 = 1.06 ft3
Volumespan = N[A x L] = 2 x [10.88 x 80.50] x (12 in./ft.)3 = 1.01 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.06 = 30.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.01 = 29.5 lbs
ws = 4.39 plf
6.71 ft.
6.42 ft.
7.00 ft.
627.85 lbs
627.85 lbs
4/27/2022 3
Fbx' = (875)(1.25)(1)(1)(1)(1.2)(1)(1) = 1312.5 psi
fb = = 460.7 psi
 fb = 460.7 psi < Fbx' = 1312.5 psi  (CSI = 0.35)   ➜  OK
4/27/2022 4
Fvx' = (135)(1.25)(1)(1)(1) = 168.75 psi
fv* = = 34.02 psi
 fv* = 34.02 psi < Fvx' = 168.75 psi  (CSI = 0.20)   ➜  OK
fv = = 41.50 psi
 fv = 41.50 psi < Fvx' = 168.75 psi  (CSI = 0.25)   ➜  OK
4/27/2022 5
ΔLL = = 0.03 in.
(L/d)LL = 80.50 / 0.03 = 2357
 ΔLL = 0.03 in = L/2357 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 80.50 / 0.06 = 1314
 ΔTL = 0.06 in = L/1314 < L/240   ➜  OK
fc⊥ = = 59.8 psi
 fc⊥ = 59.8 psi < Fc⊥x' = 425.00 psi  (CSI = 0.14)   ➜  OK
4/27/2022 6
