Grade: SP No.1
Design Span (L): 8.21 ft.
Clear Span: 8.00 ft.
Total Span: 8.42 ft.
Bearing (lb): 2.5 in.
Live Load: 400 plf
Dead Load: 80 plf
Selfweight: 59.0 lbs
Dist. Selfweight: 7.19 plf
Total Weight: 60.5 lbs
Beam Design 2022A28
1/15/2022 1
Beam Design 2022A28
1/15/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (98.50 + 2.5)] x (12 in./ft.)3 = 1.62 ft3
Volumespan = N[A x L] = 2 x [13.88 x 98.50] x (12 in./ft.)3 = 1.58 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.62 = 60.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.58 = 59.0 lbs
400 plf
80 plf
ws = 7.19 plf
8.21 ft.
8.42 ft.
2050.19 lbs
2050.19 lbs
Beam Design 2022A28
1/15/2022 3
lu/d = = 2.59
Rb = = 7.13
 Rb = 7.13 < 50   ➜  OK
Beam Design 2022A28
1/15/2022 4
FbE = = 13697.19 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1050)(1.15)(1)(1)(1)(1)(1) = 1207.50 psi
CL =   = 0.995
Fbx' = (1050)(1.15)(1)(1)(0.995)(1)(1)(1) = 1201.7 psi
fb = = 1150.8 psi
 fb = 1150.8 psi < Fbx' = 1201.7 psi  (CSI = 0.96)   ➜  OK
fv* = = 87.78 psi
 fv* = 87.78 psi < Fvx' = 201.25 psi  (CSI = 0.44)   ➜  OK
fv = = 108.08 psi
 fv = 108.08 psi < Fvx' = 201.25 psi  (CSI = 0.54)   ➜  OK
Beam Design 2022A28
1/15/2022 5
ΔLL = = 0.13 in.
(L/d)LL = 98.50 / 0.13 = 763
 ΔLL = 0.13 in = L/763 < L/180   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 98.50 / 0.16 = 627
 ΔTL = 0.16 in = L/627 < L/120   ➜  OK
Ab = b x lb = 1.5 x 2.5 = 3.75 in2
fc⊥ = = 273.4 psi
 fc⊥ = 273.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.48)   ➜  OK
Beam Design 2022A28
1/15/2022 6
