Beam Design - 4 Brightwood
Size: 5.5 x 15
Design Span (L): 22.50 ft.
Clear Span: 22.00 ft.
Total Span: 23.00 ft.
Live Load: 230 plf
Dead Load: 250 plf
Selfweight: 435.2 lbs
Dist. Selfweight: 19.34 plf
Total Weight: 444.9 lbs
CL Beam Stability Factor 0.946 - - - - -
CV Volume Factor 0.964b - - - - -
Beam Design Omid Jan Niazi 2062 Golden Gate Dr Tracy, CA 95377 4 Brightwood
4/26/2022 1
d = 15.000 in.
A = 5.500 x 15.000 = 82.50 in.2
Sx = (5.500)(15.000)2/6 = 206.25 in.3
Sy = (5.500)2(15.000)/6 = 75.63 in.3
Ix = (5.500)(15.000)3/12 = 1546.88 in.4
Iy = (5.500)3(15.000)/12 = 207.97 in.4
4/26/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [82.50 x (270.00 + 6)] x (12 in./ft.)3 = 13.18 ft3
Volumespan = N[A x L] = 1 x [82.50 x 270.00] x (12 in./ft.)3 = 12.89 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 13.18 = 444.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 12.89 = 435.2 lbs
Distributed Self Weight (ws) = = 19.34 plf
230 plf
250 plf
  ws = 19.34 plf
22.50 ft.
22.00 ft.
23.00 ft.
5742.44 lbs
5742.44 lbs
4/26/2022 3
lu = Unbraced Length = 22.500 ft.
lu/d = = 18.00
le = 1.63lu + 3d = 1.63(270.0) + 3(15) = 485.10 in. = 40.42 ft.  (NDS Table 3.3.3)
Rb = = 15.51
 Rb = 15.51 < 50   ➜  OK
4/26/2022 4
FbE = = 4240.36 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.00)(1)(1) = 2400.00 psi
CL =   = 0.946
CV = = 0.964
CL = 0.946 < CV = 0.964
Fbx' = (2400)(1.00)(1)(1)(0.946) = 2269.4 psi
fb = = 1838.5 psi
 fb = 1838.5 psi < Fbx' = 2269.4 psi  (CSI = 0.81)   ➜  OK
fv* = = 90.79 psi
4/26/2022 5
 fv* = 90.79 psi < Fvx' = 265.00 psi  (CSI = 0.34)   ➜  OK
fv = = 102.14 psi
 fv = 102.14 psi < Fvx' = 265.00 psi  (CSI = 0.39)   ➜  OK
ΔLL = = 0.48 in.
(L/d)LL = 270.00 / 0.48 = 567
 ΔLL = 0.48 in = L/567 < L/360   ➜  OK
ΔTL = = 1.03 in.
(L/d)TL = 270.00 / 1.03 = 261
 ΔTL = 1.03 in = L/261 < L/240   ➜  OK
4/26/2022 6
fc⊥ = = 174.0 psi
 fc⊥ = 174.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.27)   ➜  OK
4/26/2022 7
