Grade: SP No.1
Design Span (L): 14.00 ft.
Clear Span: 13.75 ft.
Total Span: 14.25 ft.
Live Load: 26.7 plf
Dead Load: 6.7 plf
Selfweight: 61.9 lbs
Dist. Selfweight: 4.42 plf
Total Weight: 63.0 lbs
Defl. Limits: 480|360
Beam Design 2022A270
4/26/2022 1
SP No.1 1350 875 175 565 1550 1600000 580000 0.55
4/26/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (168.00 + 3)] x (12 in./ft.)3 = 1.63 ft3
Volumespan = N[A x L] = 2 x [8.25 x 168.00] x (12 in./ft.)3 = 1.60 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 1.63 = 63.0 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 1.60 = 61.9 lbs
Distributed Self Weight (ws) = = 4.42 plf
26.7 plf
6.7 plf
ws = 4.42 plf
13.75 ft.
14.25 ft.
269.47 lbs
269.47 lbs
4/26/2022 3
Fbx' = (1350)(1.00)(0.85)(1)(1)(1)(1)(1.15) = 1319.6 psi
fb = = 735.2 psi
 fb = 735.2 psi < Fbx' = 1319.6 psi  (CSI = 0.56)   ➜  OK
4/26/2022 4
fv* = = 22.49 psi
 fv* = 22.49 psi < Fvx' = 169.75 psi  (CSI = 0.13)   ➜  OK
fv = = 24.07 psi
 fv = 24.07 psi < Fvx' = 169.75 psi  (CSI = 0.14)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
4/26/2022 5
ΔLL = = 0.39 in.
(L/d)LL = 168.00 / 0.39 = 436
 ΔLL = 0.39 in = L/436 > L/480   ➜  NG
ΔTL = = 0.55 in.
(L/d)TL = 168.00 / 0.55 = 308
 ΔTL = 0.55 in = L/308 > L/360   ➜  NG
fc⊥ = = 29.9 psi
 fc⊥ = 29.9 psi < Fc⊥x' = 378.55 psi  (CSI = 0.08)   ➜  OK
4/26/2022 6
