Beam Design - 4 Brightwood
Size: 5.5 x 13.5
Design Span (L): 22.50 ft.
Clear Span: 22.00 ft.
Total Span: 23.00 ft.
Live Load: 230 plf
Dead Load: 250 plf
Selfweight: 391.7 lbs
Dist. Selfweight: 17.41 plf
Total Weight: 400.4 lbs
CL Beam Stability Factor 0.956 - - - - -
CV Volume Factor 0.975b - - - - -
Beam Design Omid Jan Niazi 2062 Golden Gate Dr Tracy, CA 95377 4 Brightwood
4/26/2022 1
d = 13.500 in.
4/26/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [74.25 x (270.00 + 6)] x (12 in./ft.)3 = 11.86 ft3
Volumespan = N[A x L] = 1 x [74.25 x 270.00] x (12 in./ft.)3 = 11.60 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 11.86 = 400.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 11.60 = 391.7 lbs
230 plf
250 plf
  ws = 17.41 plf
22.50 ft.
22.00 ft.
23.00 ft.
5720.19 lbs
5720.19 lbs
4/26/2022 3
lu = Unbraced Length = 22.500 ft.
lu/d = = 20.00
le = 1.63lu + 3d = 1.63(270.0) + 3(13.5) = 480.60 in. = 40.05 ft.  (NDS Table 3.3.3)
Rb = = 14.65
 Rb = 14.65 < 50   ➜  OK
4/26/2022 4
FbE = = 4755.63 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.00)(1)(1) = 2400.00 psi
CL =   = 0.956
CV = = 0.975
CL = 0.956 < CV = 0.975
Fbx' = (2400)(1.00)(1)(1)(0.956) = 2293.2 psi
fb = = 2260.9 psi
 fb = 2260.9 psi < Fbx' = 2293.2 psi  (CSI = 0.99)   ➜  OK
fv* = = 101.74 psi
4/26/2022 5
 fv* = 101.74 psi < Fvx' = 265.00 psi  (CSI = 0.38)   ➜  OK
fv = = 113.05 psi
 fv = 113.05 psi < Fvx' = 265.00 psi  (CSI = 0.43)   ➜  OK
ΔLL = = 0.65 in.
(L/d)LL = 270.00 / 0.65 = 413
 ΔLL = 0.65 in = L/413 < L/360   ➜  OK
ΔTL = = 1.41 in.
(L/d)TL = 270.00 / 1.41 = 191
 ΔTL = 1.41 in = L/191 > L/240   ➜  NG
4/26/2022 6
fc⊥ = = 173.3 psi
 fc⊥ = 173.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.27)   ➜  OK
4/26/2022 7
