Beam Design - 4 Brightwood
Grade: 24F-V8 1.8E DF/DF
Size: 5.5 x 13.5
Design Span (L): 20.00 ft.
Clear Span: 19.50 ft.
Total Span: 20.50 ft.
Live Load: 200 plf
Dead Load: 180 plf
Selfweight: 348.2 lbs
Dist. Selfweight: 17.41 plf
Total Weight: 356.9 lbs
Load Duration: 1.33
CL Beam Stability Factor 0.939 - - - - -
CV Volume Factor 0.986b - - - - -
Beam Design Omid Jan Niazi 2062 Golden Gate Dr Tracy, CA 95377 4 Brightwood
4/26/2022 1
d = 13.500 in.
4/26/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [74.25 x (240.00 + 6)] x (12 in./ft.)3 = 10.57 ft3
Volumespan = N[A x L] = 1 x [74.25 x 240.00] x (12 in./ft.)3 = 10.31 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 10.57 = 356.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 10.31 = 348.2 lbs
200 plf
180 plf
  ws = 17.41 plf
19.50 ft.
20.50 ft.
4073.43 lbs
4073.43 lbs
4/26/2022 3
lu = Unbraced Length = 20.000 ft.
lu/d = = 17.78
le = 1.63lu + 3d = 1.63(240.0) + 3(13.5) = 431.70 in. = 35.97 ft.  (NDS Table 3.3.3)
Rb = = 13.88
 Rb = 13.88 < 50   ➜  OK
4/26/2022 4
FbE = = 5294.31 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.33)(1)(1) = 3192.00 psi
CL =   = 0.939
CV = = 0.986
CL = 0.939 < CV = 0.986
Fbx' = (2400)(1.33)(1)(1)(0.939) = 2996.6 psi
fb = = 1427.3 psi
 fb = 1427.3 psi < Fbx' = 2996.6 psi  (CSI = 0.48)   ➜  OK
Fvx' = (265)(1.33)(1)(1) = 352.45 psi
fv* = = 71.25 psi
4/26/2022 5
 fv* = 71.25 psi < Fvx' = 352.45 psi  (CSI = 0.20)   ➜  OK
fv = = 80.28 psi
 fv = 80.28 psi < Fvx' = 352.45 psi  (CSI = 0.23)   ➜  OK
ΔLL = = 0.35 in.
(L/d)LL = 240.00 / 0.35 = 677
 ΔLL = 0.35 in = L/677 < L/360   ➜  OK
ΔTL = = 0.70 in.
(L/d)TL = 240.00 / 0.70 = 341
 ΔTL = 0.70 in = L/341 < L/240   ➜  OK
4/26/2022 6
fc⊥ = = 123.4 psi
 fc⊥ = 123.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.19)   ➜  OK
4/26/2022 7
