Beam Design - COMPRA-1
Design Span (L): 27.75 ft.
Clear Span: 27.50 ft.
Total Span: 28.00 ft.
Selfweight: 91.5 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 92.3 lbs
Orientation: Horizontal
Beam Design GODZILLA CHAVEZ 207 NINE MILE RD HUTCHINS
4/25/2022 1
4/25/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (333.00 + 3)] x (12 in./ft.)3 = 2.70 ft3
Volumespan = N[A x L] = 1 x [13.88 x 333.00] x (12 in./ft.)3 = 2.67 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.70 = 92.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.67 = 91.5 lbs
ws = 3.30 plf
27.75 ft.
27.50 ft.
28.00 ft.
2496.14 lbs
2496.14 lbs
4/25/2022 3
Fby' = (900)(1.15)(1)(1)(1)(1.1)(1.2)(1)(1) = 1366.2 psi
fb = = 59372.5 psi
 fb = 59372.5 psi > Fby' = 1366.2 psi  (CSI = 43.46)   ➜  NG
4/25/2022 4
fv* = = 265.03 psi
 fv* = 265.03 psi > Fvy' = 207.00 psi  (CSI = 1.28)   ➜  NG
fv = = 267.44 psi
 fv = 267.44 psi > Fvy' = 207.00 psi  (CSI = 1.29)   ➜  NG
4/25/2022 5
ΔLL = = 320.54 in.
(L/d)LL = 333.00 / 320.54 = 1
 ΔLL = 320.54 in = L/1 > L/180   ➜  NG
ΔTL = = 571.51 in.
(L/d)TL = 333.00 / 571.51 = 1
 ΔTL = 571.51 in = L/1 > L/120   ➜  NG
Ab = d x lb = 9.25 x 3 = 27.75 in2
fc⊥ = = 90.0 psi
 fc⊥ = 90.0 psi < Fc⊥y' = 625.00 psi  (CSI = 0.14)   ➜  OK
4/25/2022 6
