Beam Design - 4 beam design
Grade: SPF SS
Size: 4 x 8
Design Span (L): 15.33 ft.
Clear Span: 14.67 ft.
Total Span: 16.00 ft.
Bearing (lb): 8 in.
Quantity (N): 4
Selfweight: 314.5 lbs
Dist. Selfweight: 20.51 plf
Total Weight: 328.2 lbs
Beam Design 001
4/23/2022 1
Beam Design 001
4/23/2022 2
Volumetotal = N[A x (L + lb)] = 4 x [25.38 x (184.00 + 8)] x (12 in./ft.)3 = 11.28 ft3
Volumespan = N[A x L] = 4 x [25.38 x 184.00] x (12 in./ft.)3 = 10.81 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 11.28 = 328.2 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 10.81 = 314.5 lbs
Distributed Self Weight (ws) = = 20.51 plf
ws = 20.51 plf
15.33 ft.
14.67 ft.
1564.05 lbs
1564.05 lbs
Beam Design 001
4/23/2022 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.3)(1)(1) = 1868.8 psi
fb = = 562.2 psi
 fb = 562.2 psi < Fbx' = 1868.8 psi  (CSI = 0.30)   ➜  OK
Beam Design 001
4/23/2022 4
fv* = = 20.41 psi
 fv* = 20.41 psi < Fvx' = 155.25 psi  (CSI = 0.13)   ➜  OK
fv = = 22.15 psi
 fv = 22.15 psi < Fvx' = 155.25 psi  (CSI = 0.14)   ➜  OK
Beam Design 001
4/23/2022 5
ΔLL = = 0.19 in.
(L/d)LL = 184.00 / 0.19 = 987
 ΔLL = 0.19 in = L/987 < L/360   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 184.00 / 0.36 = 505
 ΔTL = 0.36 in = L/505 < L/240   ➜  OK
fc⊥ = = 14.0 psi
 fc⊥ = 14.0 psi < Fc⊥x' = 425.00 psi  (CSI = 0.03)   ➜  OK
Beam Design 001
4/23/2022 6
