Beam Design - 4 beam design
Size: 4 x 8
Design Span (L): 15.33 ft.
Clear Span: 14.67 ft.
Total Span: 16.00 ft.
Bearing (lb): 8 in.
Quantity (N): 4
Selfweight: 369.7 lbs
Dist. Selfweight: 24.11 plf
Total Weight: 385.7 lbs
Beam Design 001
4/23/2022 1
Beam Design 001
4/23/2022 2
Volumetotal = N[A x (L + lb)] = 4 x [25.38 x (184.00 + 8)] x (12 in./ft.)3 = 11.28 ft3
Volumespan = N[A x L] = 4 x [25.38 x 184.00] x (12 in./ft.)3 = 10.81 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 11.28 = 385.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 10.81 = 369.7 lbs
Distributed Self Weight (ws) = = 24.11 plf
ws = 24.11 plf
15.33 ft.
14.67 ft.
1592.84 lbs
1592.84 lbs
Beam Design 001
4/23/2022 3
fb = = 572.5 psi
 fb = 572.5 psi < Fbx' = 1345.5 psi  (CSI = 0.43)   ➜  OK
Beam Design 001
4/23/2022 4
fv* = = 20.78 psi
 fv* = 20.78 psi < Fvx' = 207.00 psi  (CSI = 0.10)   ➜  OK
fv = = 22.56 psi
 fv = 22.56 psi < Fvx' = 207.00 psi  (CSI = 0.11)   ➜  OK
Beam Design 001
4/23/2022 5
ΔLL = = 0.17 in.
(L/d)LL = 184.00 / 0.17 = 1052
 ΔLL = 0.17 in = L/1052 < L/360   ➜  OK
ΔTL = = 0.35 in.
(L/d)TL = 184.00 / 0.35 = 529
 ΔTL = 0.35 in = L/529 < L/240   ➜  OK
fc⊥ = = 14.2 psi
 fc⊥ = 14.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.02)   ➜  OK
Beam Design 001
4/23/2022 6
