Grade: SP No.1
Design Span (L): 9.33 ft.
Clear Span: 9.12 ft.
Total Span: 9.54 ft.
Bearing (lb): 2.5 in.
Live Load: 280 plf
Dead Load: 62.5 plf
Selfweight: 69.4 lbs
Dist. Selfweight: 7.44 plf
Total Weight: 70.9 lbs
Beam Design 2022A257
4/23/2022 1
4/23/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (112.00 + 2.5)] x (12 in./ft.)3 = 1.84 ft3
Volumespan = N[A x L] = 2 x [13.88 x 112.00] x (12 in./ft.)3 = 1.80 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 1.84 = 70.9 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 1.80 = 69.4 lbs
Distributed Self Weight (ws) = = 7.44 plf
280 plf
62.5 plf
ws = 7.44 plf
9.33 ft.
9.12 ft.
9.54 ft.
1669.42 lbs
1669.42 lbs
4/23/2022 3
Fbx' = (1050)(1.00)(1)(1)(1)(1)(1)(1) = 1050.0 psi
fb = = 1068.7 psi
 fb = 1068.7 psi > Fbx' = 1050.0 psi  (CSI = 1.02)   ➜  NG
4/23/2022 4
fv* = = 73.69 psi
 fv* = 73.69 psi < Fvx' = 169.75 psi  (CSI = 0.43)   ➜  OK
fv = = 88.27 psi
 fv = 88.27 psi < Fvx' = 169.75 psi  (CSI = 0.52)   ➜  OK
4/23/2022 5
ΔLL = = 0.17 in.
(L/d)LL = 112.00 / 0.17 = 668
 ΔLL = 0.17 in = L/668 < L/360   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 112.00 / 0.21 = 534
 ΔTL = 0.21 in = L/534 < L/240   ➜  OK
Ab = b x lb = 1.5 x 2.5 = 3.75 in2
fc⊥ = = 222.6 psi
 fc⊥ = 222.6 psi < Fc⊥x' = 378.55 psi  (CSI = 0.59)   ➜  OK
4/23/2022 6
