Grade: SP No.1
Design Span (L): 6.50 ft.
Clear Span: 6.29 ft.
Total Span: 6.71 ft.
Bearing (lb): 2.5 in.
Live Load: 560 plf
Dead Load: 140 plf
Selfweight: 48.3 lbs
Dist. Selfweight: 7.44 plf
Total Weight: 49.9 lbs
Beam Design 2022A256
4/23/2022 1
4/23/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (78.00 + 2.5)] x (12 in./ft.)3 = 1.29 ft3
Volumespan = N[A x L] = 2 x [13.88 x 78.00] x (12 in./ft.)3 = 1.25 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 1.29 = 49.9 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 1.25 = 48.3 lbs
Distributed Self Weight (ws) = = 7.44 plf
560 plf
140 plf
ws = 7.44 plf
6.50 ft.
6.29 ft.
6.71 ft.
2372.86 lbs
2372.86 lbs
4/23/2022 3
Fbx' = (1050)(1.00)(1)(1)(1)(1)(1)(1) = 1050.0 psi
fb = = 1048.0 psi
 fb = 1048.0 psi < Fbx' = 1050.0 psi  (CSI = 1.00)   ➜  OK
4/23/2022 4
fv* = = 94.80 psi
 fv* = 94.80 psi < Fvx' = 169.75 psi  (CSI = 0.56)   ➜  OK
fv = = 124.28 psi
 fv = 124.28 psi < Fvx' = 169.75 psi  (CSI = 0.73)   ➜  OK
4/23/2022 5
ΔLL = = 0.08 in.
(L/d)LL = 78.00 / 0.08 = 988
 ΔLL = 0.08 in = L/988 < L/360   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 78.00 / 0.10 = 782
 ΔTL = 0.10 in = L/782 < L/240   ➜  OK
Ab = b x lb = 1.5 x 2.5 = 3.75 in2
fc⊥ = = 316.4 psi
 fc⊥ = 316.4 psi < Fc⊥x' = 378.55 psi  (CSI = 0.84)   ➜  OK
4/23/2022 6
