Beam Design - JaxPort Bracing
Design Span (L): 1.92 ft.
Clear Span: 1.76 ft.
Total Span: 2.09 ft.
Bearing (lb): 2 in.
Live Load: 300 plf
Dead Load: 500 plf
Selfweight: 16.8 lbs
Dist. Selfweight: 8.74 plf
Total Weight: 18.3 lbs
Orientation: Horizontal
Incised Lumber: Yes
Ct Temperature Factor 0.7 0.9 0.7 0.7 0.7 0.9
Beam Design Sheldon Gibbs 7400 Baymeadows Way, Suite 215, Jacksonville, FL 32256 004-030
4/20/2022 1
4/20/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (23.08 + 2)] x (12 in./ft.)3 = 0.47 ft3
Volumespan = N[A x L] = 3 x [10.88 x 23.08] x (12 in./ft.)3 = 0.44 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.47 = 18.3 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.44 = 16.8 lbs
Distributed Self Weight (ws) = = 8.74 plf
300 plf
500 plf
ws = 8.74 plf
1.92 ft.
1.76 ft.
2.09 ft.
845.00 lbs
845.00 lbs
4/20/2022 3
Fby' = (925)(1.00)(1)(0.7)(1)(1)(1.15)(0.8)(1) = 595.7 psi
fb = = 550.0 psi
 fb = 550.0 psi < Fby' = 595.7 psi  (CSI = 0.92)   ➜  OK
4/20/2022 4
Fvy' = (175)(1.00)(0.97)(0.7)(0.8) = 95.06 psi
fv* = = 31.10 psi
 fv* = 31.10 psi < Fvy' = 95.06 psi  (CSI = 0.33)   ➜  OK
fv = = 35.75 psi
 fv = 35.75 psi < Fvy' = 95.06 psi  (CSI = 0.38)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1400000(0.9)(0.9)(0.95) = 1077300 psi
4/20/2022 5
ΔLL = = 0.01 in.
(L/d)LL = 23.08 / 0.01 = 1648
 ΔLL = 0.01 in = L/1648 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 23.08 / 0.04 = 611
 ΔTL = 0.04 in = L/611 < L/240   ➜  OK
Fc⊥y' = (565)(0.67)(0.7)(1) = 264.99 psi
Ab = d x lb = 7.25 x 2 = 14.50 in2
fc⊥ = = 19.4 psi
 fc⊥ = 19.4 psi < Fc⊥y' = 264.99 psi  (CSI = 0.07)   ➜  OK
4/20/2022 6
